Well, I re-coded with a pair of mixers driven by a two bit counter. The MSD drives the I mixer while the Ex-Or of LSD and MSD drive the Q mixer. (Ex-Or gives quadrature according to my simple Karnaugh map) The mixers either pass the direct signal or invert it (multiply by -1) Sady it still doesn't work No sideband supression at all (but I'm still checking the code). Any ideas ? ................. Zim -- Posted via a free Usenet account from http://www.teranews.com
Digital synthesis of Quadrature, please help
Started by ●January 15, 2007
Reply by ●January 15, 20072007-01-15
Reply by ●January 16, 20072007-01-16
Well, I have it working. I was incrementing a register to make a Local Oscillator (clock). The problem was that in this beast the registers do not wrap around. They just limit at full scale. Thus the clock was only running in a short burst. The good news is that the sideband suppression is now incredibly high, with effectively immeasurable leakage. The bad news is that there is an image response (as I suspected ther would be). With the Local Osc at 8 KHz (32 KHz clock / 4), there is an image at +/- 8KHz centered on DC. More thinking required. ...................... Zim -- Posted via a free Usenet account from http://www.teranews.com
Hi Graeme, I see you have got I and Q signal entering the DSP. Why have you a Hilbert transform filter on the Q input. Surely you just need the same filter as is on the I branch, as you already have the signals with a 90 degree phase difference. Regards Bob Graeme Zimmer wrote:> Greetings, > > I have a nice little DSP radio working, see > http://members.wideband.net.au/gzimmer/DSP_Rx/SimpleRX.html > > It uses two mixers to develop the quadrature data streams. > > I figured that I could eliminate the quadrature mixers, > if I could synthesise the quadrature streams in software. > > I used a rolling buffer with taps 1&2 summed for one stream > and taps 2&3 summed for the other. > > Trouble is I get no sideband separation at all. > > I'd be gratefull if someone could steer me in the right direction. > > Thanks in advance. > > ........................... Zim > > > > -- > Posted via a free Usenet account from http://www.teranews.com
Hi Bob, I think you are confusing two different schemes, Phasing mehod and Weaver method. see http://www.nxp.com/acrobat_download/applicationnotes/AN1981.pdf and http://www.doug-smith.net/hifidesign1.htm Regards ............. Zim -- Posted via a free Usenet account from http://www.teranews.com
Yeah, I wasn't considering the details. Bob Graeme Zimmer wrote:> Hi Bob, > > I think you are confusing two different schemes, Phasing mehod and Weaver > method. > > see http://www.nxp.com/acrobat_download/applicationnotes/AN1981.pdf > > and http://www.doug-smith.net/hifidesign1.htm > > > Regards ............. Zim > > > > -- > Posted via a free Usenet account from http://www.teranews.com
Bob, I've put a description of my new version on my web page at: http://members.wideband.net.au/gzimmer/ It's under "An even Simpler DSP Receiver" Thanks ............. Zim .............. VK3GJZ -- Posted via a free Usenet account from http://www.teranews.com
"Graeme Zimmer" <gzimmer@wideband.net.au> writes:> Greetings, > > I have a nice little DSP radio working, see > http://members.wideband.net.au/gzimmer/DSP_Rx/SimpleRX.html > > It uses two mixers to develop the quadrature data streams. > > I figured that I could eliminate the quadrature mixers, > if I could synthesise the quadrature streams in software. > > I used a rolling buffer with taps 1&2 summed for one stream > and taps 2&3 summed for the other. > > Trouble is I get no sideband separation at all. > > I'd be gratefull if someone could steer me in the right direction. > > Thanks in advance. > > ........................... ZimHi Zim, Are you saying you're looking for a software quadrature oscillator? If so, then check out Clay Turner's excellent article on oscillators that was in the IEEE Signal Processing magazine: http://www.claysturner.com/dsp/2nd_OSC_paper.pdf -- % Randy Yates % "Though you ride on the wheels of tomorrow, %% Fuquay-Varina, NC % you still wander the fields of your %%% 919-577-9882 % sorrow." %%%% <yates@ieee.org> % '21st Century Man', *Time*, ELO http://home.earthlink.net/~yatescr
