Dear all, I am modelling phase noise for OFDM systems. At the receiver r=s*exp(j*phi)+w r= received signal s=transmitted signal phi=random phase w = AWGN noise I have studied in the literature that phase noise can be described as sampled version of wiener process, but for the purpose of analysis and simulations a discrete time random walk or weiner levy process is used. What exactly is this weiner levy process, how could i model it in matlab?
phase noise
Started by ●January 15, 2007
Reply by ●January 16, 20072007-01-16
aamer wrote:> I have studied in the literature that phase noise can be described as > sampled version of wiener process, but for the purpose of analysis and > simulations a discrete time random walk or weiner levy process is used. > What exactly is this weiner levy process, how could i model it in matlab?The Wiener process is a special case of the Levy process. For your purposes, it's probably sufficient to generate a Wiener process by: x = randn(N.1); h = some filter with the appropriate Fourier transform y = conv(x,h); Basically generate a discrete-time white Gaussian sequence and then filter it using filter h. Choose h according to what you want. I have seen phase noise models where h is a lowpass filter, for example. Hope that helps, Julius
