Hi, A basic question about QAM. I've noticed that there are timing recovery systems that calculate the 'correct' sample by means of an interpolation guessing wich one of this intermediate samples is the most suitable instead of closing a loop and recovering and using the recovered clock as a receiver clock.. It seems to me quite interesting but I have a doubt: If we don't synchronize the transmiter/Receiver clock adjusting the symbol clock, is not possible to loose a packet of bits? The scenario I'm figuring out is a Tx working with its clock, and a Rx with a slightly different one because of component tolerance, since we don't modyfy the clock (just reinvent the sample by interpolation) Then, if the Rx clock freq is slightly lower than the Tx, and we don't correct this, in the end we'll overrun a sample...Won't we? Am I missing some point about this method? Any paper/review about this issue will be welcomed. Thanks.
Timing recovery by oversampling in QAM systems
Started by ●January 17, 2007
Reply by ●January 17, 20072007-01-17
Calabi_yau wrote:> It seems to me quite interesting but I have a doubt: If we don't > synchronize the transmiter/Receiver clock adjusting the symbol clock, is > not possible to loose a packet of bits? > > The scenario I'm figuring out is a Tx working with its clock, and a Rx > with a slightly different one because of component tolerance, since we > don't modyfy the clock (just reinvent the sample by interpolation) > > Then, if the Rx clock freq is slightly lower than the Tx, and we don't > correct this, in the end we'll overrun a sample...Won't we?No, because like you said the receiver samples above the bandwidth of the transmitted signal. Think about it: if you are sampling above the Nyquist rate of the transmit signal, then you can reconstruct the signal anyway, and then re-sample at the correct instances. Thankfully, the same thing can be done by using a timing estimator, timing adjustor, and using this adjusted estimate to feed into an interpolator -- all in the discrete-time domain. Hope that helps, Julius
