Hi, I am trying to apply 2D FIR filters to an image. wat is the difference btwn using conv2 and filter2? When i use conv2, I can obtain an image of the same size as the original image, but if i were to use filter2, the result is only a few pixels. another question is upon reading in an image using imread, do i need to convert to ycbcr format before i perform the conv2 or filter2? Urgent help is needed and any advice given is much appreciated. Best Regards, fulltime
what is the difference btwn conv2 and filter2 in matlab?
Started by ●January 22, 2007
Reply by ●January 23, 20072007-01-23
fulltime wrote:> Hi, > > I am trying to apply 2D FIR filters to an image. wat is the difference > btwn using conv2 and filter2? > > When i use conv2, I can obtain an image of the same size as the > original image, but if i were to use filter2, the result is only a few > pixels. > > another question is upon reading in an image using imread, do i need to > convert to ycbcr format before i perform the conv2 or filter2? > > Urgent help is needed and any advice given is much appreciated. > > Best Regards, > fulltime >I don't use Matlab often anymore, but I remember using the 1-D equivalent functions, i.e. filter and conv. I believe the difference comes down to the number of samples in the output. For example let's say you have input x and impulse response h to give you an output y (with respective lengths len_x, len_h, len_y). When using the filter function len_y will be len_x, but when using the conv function then len_y will equal len_x+len_h-1. Brad
