As was kindly suggested to me, I've been experimenting with OFDM for my TCP/IP over tin cans project. Since the modulation on the "wire" is at baseband, and I'm using a sound card as a DAC, this means my signals are audible. When modulating a random bitstream, the resulting audio is full of popping noises. I have taken steps to ensure that no clipping is occurring, so these pops are really a part of the signal, not nonlinear effects. Am I hearing the effects of OFDM's high PAPR? It's true that this channel is very dispersive, but the characteristics should be constant with time, because I am trying to idealize the implementation. As long as the channel is reasonably linear, shouldn't I be able to counter this dispersion by deconvolution? I realize that the FIR kernel might be quite large. If that's possible, I'd prefer to use some other modulation with better PAPR characteristics. Also, any ideas how I might measure the degree of linearity of the system? I was thinking of sweeping a band-pass filter across some white noise and looking at the spectrum at the receiver. Any nonlinearity should manifest as energy outside of the original band limits, correct? I suppose the nonlinearity could somehow stay entirely within the band (imagine randomly reordering the values of the FFT bins, but staying within the band limits) but I think the chances of that being the case are fairly remote. Thanks, Scott
Tin can modulation, OFDM, PAPR
Started by ●January 23, 2007
Reply by ●January 24, 20072007-01-24
Hi Scott, Seems Don Quixote is alive and well. :-) Scott L wrote:> As was kindly suggested to me, I've been experimenting with OFDM for my > TCP/IP over tin cans project. Since the modulation on the "wire" is at > baseband, and I'm using a sound card as a DAC, this means my signals > are audible. > > When modulating a random bitstream, the resulting audio is full of > popping noises. I have taken steps to ensure that no clipping is > occurring, so these pops are really a part of the signal, not nonlinear > effects. Am I hearing the effects of OFDM's high PAPR? > > It's true that this channel is very dispersive, but the characteristicsA good way to reduce dispersion might be to choose the string wisely. A monofilament should improve things. Say, a thin fibre of glass, held under light tension. You don't usually see people trying OFDM over fibre :-)> should be constant with time, because I am trying to idealize the > implementation. As long as the channel is reasonably linear, shouldn't > I be able to counter this dispersion by deconvolution? I realize that > the FIR kernel might be quite large. If that's possible, I'd prefer to > use some other modulation with better PAPR characteristics. > > Also, any ideas how I might measure the degree of linearity of the > system? I was thinking of sweeping a band-pass filter across some white > noise and looking at the spectrum at the receiver. Any nonlinearity > should manifest as energy outside of the original band limits, correct? > I suppose the nonlinearity could somehow stay entirely within the band > (imagine randomly reordering the values of the FFT bins, but staying > within the band limits) but I think the chances of that being the case > are fairly remote.Regards, Steve
Scott L wrote:> As was kindly suggested to me, I've been experimenting with OFDM for my > TCP/IP over tin cans project. Since the modulation on the "wire" is at > baseband, and I'm using a sound card as a DAC, this means my signals > are audible. > > When modulating a random bitstream, the resulting audio is full of > popping noises. I have taken steps to ensure that no clipping is > occurring, so these pops are really a part of the signal, not nonlinear > effects. Am I hearing the effects of OFDM's high PAPR? > > It's true that this channel is very dispersive, but the characteristics > should be constant with time, because I am trying to idealize the > implementation. As long as the channel is reasonably linear, shouldn't > I be able to counter this dispersion by deconvolution? I realize that > the FIR kernel might be quite large. If that's possible, I'd prefer to > use some other modulation with better PAPR characteristics. > > Also, any ideas how I might measure the degree of linearity of the > system? I was thinking of sweeping a band-pass filter across some white > noise and looking at the spectrum at the receiver. Any nonlinearity > should manifest as energy outside of the original band limits, correct? > I suppose the nonlinearity could somehow stay entirely within the band > (imagine randomly reordering the values of the FFT bins, but staying > within the band limits) but I think the chances of that being the case > are fairly remote. > > Thanks, > Scott >AFAIK the 'pop' can be quite smeared, as long as it doesn't get distorted by a nonlinearity (which would spill energy into other symbols), and as long as the dispersion is a smallish fraction of the symbol time of your OFDM. If you're actually doing this, why don't you try measuring the dispersion of the line? Give it a nice narrow but bandlimited pulse, like a time-limited sync pulse or a Gaussian or some such, and see what comes out the other end. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
On Wed, 24 Jan 2007 20:20:24 +0800, Steve Underwood <steveu@dis.org> wrote:>Hi Scott, > >Seems Don Quixote is alive and well. :-) > >Scott L wrote: >> As was kindly suggested to me, I've been experimenting with OFDM for my >> TCP/IP over tin cans project. Since the modulation on the "wire" is at >> baseband, and I'm using a sound card as a DAC, this means my signals >> are audible. >> >> When modulating a random bitstream, the resulting audio is full of >> popping noises. I have taken steps to ensure that no clipping is >> occurring, so these pops are really a part of the signal, not nonlinear >> effects. Am I hearing the effects of OFDM's high PAPR? >> >> It's true that this channel is very dispersive, but the characteristics > >A good way to reduce dispersion might be to choose the string wisely. A >monofilament should improve things. Say, a thin fibre of glass, held >under light tension. You don't usually see people trying OFDM over fibre :-)Actually there's a move to multiple-wavelength transmission on fibers, but I think you're right that they're not orthogonal. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
On 23 Jan 2007 16:56:20 -0800, "Scott L" <scott-sp02@neuralnw.com> wrote:>As was kindly suggested to me, I've been experimenting with OFDM for my >TCP/IP over tin cans project. Since the modulation on the "wire" is at >baseband, and I'm using a sound card as a DAC, this means my signals >are audible. > >When modulating a random bitstream, the resulting audio is full of >popping noises. I have taken steps to ensure that no clipping is >occurring, so these pops are really a part of the signal, not nonlinear >effects. Am I hearing the effects of OFDM's high PAPR?Possibly, and if so, are you using a scrambler? Just whitening the data goes a long ways toward reducing PAPR in OFDM. Also look carefully at the arrangement of any pilot tones or preamble/channel estimation sequences that you are using, as they need to be considered for PAPR as well.>It's true that this channel is very dispersive, but the characteristics >should be constant with time, because I am trying to idealize the >implementation. As long as the channel is reasonably linear, shouldn't >I be able to counter this dispersion by deconvolution? I realize that >the FIR kernel might be quite large. If that's possible, I'd prefer to >use some other modulation with better PAPR characteristics.If the OFDM symbol rate is low enough it may be that a cyclic-prefix is all that is needed. I guess I'm not completely seeing the connection between the dispersion and PAPR? In any case, I agree with the previous posts that characterizing the channel transfer function is a good idea. I think I'd look at it with different string types, string tensions, can diameters, etc. You could spend a ton of time just on channel characterization, though, and you probably want to get on with the system design.>Also, any ideas how I might measure the degree of linearity of the >system? I was thinking of sweeping a band-pass filter across some white >noise and looking at the spectrum at the receiver. Any nonlinearity >should manifest as energy outside of the original band limits, correct? >I suppose the nonlinearity could somehow stay entirely within the band >(imagine randomly reordering the values of the FFT bins, but staying >within the band limits) but I think the chances of that being the case >are fairly remote.Rather than a BPF sweep with noise, why not sweep a linear FM and recover magnitude *and* phase in the receiver. That gives about as complete of a picture as possible. For nonlinearity assessment you may want to do that at increasing power levels, i.e., FM sweep, increase power, FM sweep, increase power, sweep again, etc. At some point any nonlinearity and it's characteristic will become apparent. Or, to save time, you could do a single FM sweep and pick a few frequencies to test based on the results. Start a tone at a frequency of interest and gradually increase the power and see what happens. I think it's an interesting problem and just getting good characterizations of the channel and the effects of the string types, tension, and can types, diameters, etc., would be interesting. Not real useful, but interesting anyway... ;) Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
On Jan 24, 11:13 am, Eric Jacobsen <eric.jacob...@ieee.org> wrote:> >When modulating a random bitstream, the resulting audio is full of > >popping noises. I have taken steps to ensure that no clipping is > >occurring, so these pops are really a part of the signal, not nonlinear > >effects. Am I hearing the effects of OFDM's high PAPR?> Possibly, and if so, are you using a scrambler? Just whitening the > data goes a long ways toward reducing PAPR in OFDM. Also look > carefully at the arrangement of any pilot tones or preamble/channel > estimation sequences that you are using, as they need to be considered > for PAPR as well.There is no scrambler or coding at this stage. My first attempt was a modulation of several kb of straight ASCII text, which has a fairly low entropy (and a few bit magnitudes which never change their values!). When I moved to random data as the input, the popping was greatly reduced but still apparent. With no mathematical justification whatsoever, I tried using different base phases on each subcarrier (right now the carrier modulation is BPSK). This made a difference but not much.> >It's true that this channel is very dispersive, but the characteristics > >should be constant with time, because I am trying to idealize the > >implementation. As long as the channel is reasonably linear, shouldn't > >I be able to counter this dispersion by deconvolution? I realize that > >the FIR kernel might be quite large. If that's possible, I'd prefer to > >use some other modulation with better PAPR characteristics.> If the OFDM symbol rate is low enough it may be that a cyclic-prefix > is all that is needed. I guess I'm not completely seeing the > connection between the dispersion and PAPR?It's not really a connection. What I meant is that OFDM was suggested because of its good performance on dispersive channels. If I can remove the dispersion by deconvolution then I don't have to deal with it and that gives me more options besides OFDM. Or is this wrong thinking? As for a cyclic prefix... I can't experiment usefully with that until I know the appropriate guard interval to use, which I can't determine yet because my rig isn't built.> In any case, I agree with the previous posts that characterizing the > channel transfer function is a good idea. I think I'd look at it > with different string types, string tensions, can diameters, etc. You > could spend a ton of time just on channel characterization, though, > and you probably want to get on with the system design.Yes, I want to do this as soon as possible. My biggest problem at the moment is shielding the transmitter and receiver so that the receiver cannot hear the sound directly through the air -- I want it only to hear the signal coming from the can. I'm lacking the materials to do this properly so I have to improvise. I'm having trouble finding a small speaker that can fit right inside the mouth of the can and also matches the impedance of the sound card audio output. And the mic I'm working with currently is cheap.> >Also, any ideas how I might measure the degree of linearity of the > >system? I was thinking of sweeping a band-pass filter across some white > >noise and looking at the spectrum at the receiver. Any nonlinearity > >should manifest as energy outside of the original band limits, correct? > >I suppose the nonlinearity could somehow stay entirely within the band > >(imagine randomly reordering the values of the FFT bins, but staying > >within the band limits) but I think the chances of that being the case > >are fairly remote.> Rather than a BPF sweep with noise, why not sweep a linear FM and > recover magnitude *and* phase in the receiver. That gives about as > complete of a picture as possible. For nonlinearity assessment you > may want to do that at increasing power levels, i.e., FM sweep, > increase power, FM sweep, increase power, sweep again, etc. At some > point any nonlinearity and it's characteristic will become apparent. > > Or, to save time, you could do a single FM sweep and pick a few > frequencies to test based on the results. Start a tone at a > frequency of interest and gradually increase the power and see what > happens.Good suggestions, thanks.> Not real useful, but interesting anyway... ;)Steve Underwood's characterization of me as "Don Quixote" is fairly accurate... Thanks again, Scott
