Dear Sir, I am working on Acoustic Echo Cancellation using LMS algorithm in time domain.I have written the code for this.It is working fine that its output signal has only the near end signal with a very very small hiss sound in the situation when both farend and near end signals are talked simultaneously. As large eigen value spread and double talk situation are two major drawbacks of LMS algorithm for Acoustic Echo Cancellation(AEC), for large eigen value spread I have introduced Elliptic IIR filter and Polyphase IIR filter and I have integrated them in the code of AEC separately and I observed its outputs separatelY. But I dont see much difference in the outputs of basic AEC using LMS and the AEC with subband approach.They are almost similar with some hiss sound in the double talk situation.So now I am seeing Double Talk Detection(DTD). We know that double talk situation is nothing but the situation when both farend and near end speach signals occur at a time, during which there will be poor AEC performance.To avoid this when DT occurs we need to freeze the updation of weights in AEC. But the problem is, how to detect double talk situation?It is mentioned in some documents that basing on the signal energies we will detect the double talk situation by setting some threshhold.But it is not mentioned clearly that how to take this threshhold value. If anyone have idea regarding this please give some valuable suggestions. Thanks in advance. Regards, Aparna Ram.K.
Regarding double talk detection in Acoustic Echo Cancellation
Started by ●January 24, 2007
Reply by ●January 24, 20072007-01-24
Aparna Ram wrote:> But the problem is, how to detect double talk situation?It > is mentioned in some documents that basing on the signal energies we > will detect the double talk situation by setting some threshhold.It is dead simple. The transmitted power is known, the received power is known, the coupling between the speaker and the mike is also known approximately. Therefore you can set a threshold based on transmit/receive power ratio. If the ratio is below the threshold, that means that the received signal is dominated by the sound from the ambience. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Aparna Ram wrote:> Dear Sir, > > I am working on Acoustic Echo Cancellation using LMS > algorithm in time domain.I have written the code for this.It is working > fine that its output signal has only the near end signal with a very > very small hiss sound in the situation when both farend and near end > signals are talked simultaneously. As large eigen value spread and > double talk situation are two major drawbacks of LMS algorithm for > Acoustic Echo Cancellation(AEC), for large eigen value spread I have > introduced Elliptic IIR filter and Polyphase IIR filter and I have > integrated them in the code of AEC separately and I observed its > outputs separatelY. > > But I dont see much difference in the outputs of basic AEC > using LMS and the AEC with subband approach.They are almost similar > with some hiss sound in the double talk situation.So now I am seeing > Double Talk Detection(DTD). > > We know that double talk situation is nothing but the > situation when both farend and near end speach signals occur at a time, > during which there will be poor AEC performance.To avoid this when DT > occurs we need to freeze the updation of weights in AEC. > > But the problem is, how to detect double talk situation?It > is mentioned in some documents that basing on the signal energies we > will detect the double talk situation by setting some threshhold.But it > is not mentioned clearly that how to take this threshhold value.The commonest approach is something called the Geigel algorithm. Very simple, very crude, but rather flaky. Its simplicity means its a good place to start, but it probably won't build you a world class echo canceller. :-\ Basically you use a decision like "if the short term receive power is greater than half the short term transmit power it can't all be echo, so we have double talk". There are various temporal assumptions in that, and it assumes the far end talker will be fairly loud. Its is, thus, a far from perfect decision criterion.> If anyone have idea regarding this please give some valuable > suggestions.Steve
