Hi, I have enabled "Mixed Source/ASM" under the View Menu. But, i am unable to view Both the C Code and the corresponding Assembly instructions together . :( :( :( :( !!!!! I am following the rules exactly as told in the CCS. Is there any bug in this feature in CCS v3.1 ?? I do as per the below info from CCS Help, But i am still unable to view Disassembled Instructions of each C statement within the sourcecode : " To View Mixed C Source and Assembly Code, After loading a program onto your target or simulator: 1) Select View?Mixed Source/ASM. A check mark identifies when this option is selected. 2) Select Debug?Go Main. The debugger starts executing the program and stops execution at main(). The associated C source file is automatically displayed in an Editor window. Notice that the disassembled instructions for each C statement appear within the source code. Just as in the Disassembly window, the location of the PC is highlighted in yellow. " Why does CCS does not show the Assembly of the corresponding C Source ? Kindly let me know some solutions. Thx in advans, Karthik Balaguru
CCS does not show the Disassembled Assembly of the corresponding C Source in "Mixed Source/ASM" Mode
Started by ●January 26, 2007
