Hi, I have a question about decoding Reed Solomon code used in 802.16 standard. In the 802.16-2004 document, RS(255,239,8) is used, but the output is usually punctured to produce shorter codeword, RS(40,36,2) for example. The question is: because the parity bytes is reduce from 16 bytes to 4 (first) bytes, how we design the decoder? Padding zero bytes to the parity and data to form RS(255,239,8) decoder? Wrong, because the 4 parity bytes can correct the total of 12 parity bytes (0 padding) and (xxx) data bytes.Or we must design a RS(40,36,2) decoder, but the code generation polynomial is changed(?). Pls give me advice. Thank you.
Question about Reed Solomon decoder for 802.16
Started by ●January 29, 2007
Reply by ●January 30, 20072007-01-30
Sorry because I have asked such @#$%^& question. Just think again, I realize that the decoder would be RS(255,239) with 12 erasures corresponding to 12 cleared parity bytes (for RS(40,36,2) code), and it can still correct 2 other errors. :D
Reply by ●February 9, 20072007-02-09
>Sorry because I have asked such @#$%^& question. Just think again, I >realize that the decoder would be RS(255,239) with 12 erasures >corresponding to 12 cleared parity bytes (for RS(40,36,2) code), and it >can still correct 2 other errors. >:D > > >How did you manage to undo the shortening? I thought reordering the sequence and using zero padding would be enough, but the output is not working. Thanks in advance. Victor
