When running the g21 c-compiler for the ADSP-21xx, The dos window chrashes with the following error pop-up: MS-DOS Prompt X#=0C, CS=019F IP=00001856. The NTVDM CPU has encountered an unhandled exception. Choose 'Close to terminate the application. It used to work fine for a long time, but after installing Microsoft security patches.... Has anyone else this problem, and a solution ? /Jens
problem running g21 c-compiler under windows 2000
Started by ●June 1, 2004
Reply by ●June 3, 20042004-06-03
a.b.renner@gmx.de (Jens Peter Jacobsen) wrote in message news:<f67d78a4.0406010010.7ddb7416@posting.google.com>...> When running the g21 c-compiler for the ADSP-21xx, The dos window > chrashes with the following error pop-up: > > MS-DOS Prompt > X#=0C, CS=019F IP=00001856. The NTVDM CPU has encountered an unhandled > exception. Choose 'Close to terminate the application. > > It used to work fine for a long time, but after installing Microsoft > security patches.... > > Has anyone else this problem, and a solution ? > > /JensYup, Microsoft has continuing legacy compatibility issues. The solution is to install Linux and run the ADI tools in DOSemu, Wine, or CrossoverOffice: http://www.aerospacesoftware.com http://www.aerospacesoftware.com/contents.htm http://www.aerospacesoftware.com/howto_dosemu.htm Linux is a veritable Rosetta Stone of computer systems... Cheers, Herman http://www.AerospaceSoftware.com
