Hello all, I also tried to implement a cyclic code with very high values of (n,k)=(117,102). When I tried that and check if the code is able to correct all the 2 bit errors, it was not able to do that. The minimum distance for the code is 6 but it was not able to correct all the 2 bit errors. Could you let me know why this is happening. I have one more question about the REED SOLOMON CODES. Lets say n=31 and k=25 in the RS codes. This means it can correct (n-k)/2 symbols or 15 bits. Now does the Reed Solomom codes correct any 15 bit errors that occur all over the data frame of 31*5=155 bits or does it correct only three symbols and leave the remaining bit error as they are. Please clarify me about this... Thanks and Regards, Krishna Chaitanya.
Regarding the working of Cyclic Codes
Started by ●February 9, 2007
