Hi, I have implemented a 256 pts FFT at 10.24 MHz sampling frequency so I have a frequency resolution of 40 kHz... I compute the FFT output to have the squared magnitude : Re(X(m))^2 + Im(X(m))^2 When I send a pure 500kHz sine to the ADC input (12 bits) I see on the FFT output one peak at bin frequency 500 kHz and 9.74 MHz Then when I send 510kHz sine to the ADC I read on the FFT output : one bin at 510 kHz one bin at 9.73 MHz and one bin at 8.23 MHz and at 7.24 MHz Why I have got these two bins 8.23 and 7.24 ? what's happen, it's like an intermodulation on my signals ?? With rectangular or flat top windows I have these two strange bins... thanks for any help
FFT problem
Started by ●February 13, 2007
Reply by ●February 13, 20072007-02-13
I have another problem... When I send a pure 500 kHz sine, when I don't have the stranger frequency at 8.23 and 7.24 I can see that the magnitude of the FFT varies in amplitude over the time, it's like the "picket fence" effect that we have when the input frequency send to the FFT is increasing over the time... So it's like an amplitude modulation on my FFT magnitude.... because the frequency sent to the ADC is asynchronous to the frequency sampling used by my ADC and my FFT how to don't have this problem ? thanks
On 13 Feb 2007 03:16:56 -0800, patrick.melet@dmradiocom.fr wrote:>Hi, > >I have implemented a 256 pts FFT at 10.24 MHz sampling frequency so I >have a frequency resolution of 40 kHz... > >I compute the FFT output to have the squared magnitude : Re(X(m))^2 + >Im(X(m))^2 > >When I send a pure 500kHz sine to the ADC input (12 bits) I see on the >FFT output one peak at bin frequency 500 kHz and 9.74 MHz > >Then when I send 510kHz sine to the ADC I read on the FFT output : one >bin at 510 kHz one bin at 9.73 MHz and one bin at 8.23 MHz and at 7.24 >MHz > >Why I have got these two bins 8.23 and 7.24 ? what's happen, it's like >an intermodulation on my signals ?? > >With rectangular or flat top windows I have these two strange bins... > >thanks for any helpHello Patrick, wow, what a strange problem! When you're FFT input is 500 kHz, your FFT magnitude results are correct. (Now if you run that 500 kHz test ten times your magnitude results should always be the same, but your spectral phase will probably be different for each test.) If your FFT software is working properly then your 510 kHz test should also work. But what puzzles me is that during your 510 kHz test, your spectral magnitudes are *NOT* symmetrically centered at 5.12 MHz (Fs/2)! That implies that the input sequence values to your FFT are complex-valued time samples rather than real-only time samples. (Can you trust your FFT software? What makes you think that software is correct?) Soooo, ... either your FFT software is not working properly (but I'll bet it is), or you are not really applying the time samples to your FFT that you think you are. I suggest that you, somehow, very carefully examine the time samples that you are applying to the FFT during your 510 kHz test. Then again, maybe your FFT software is working, and your FFT input samples are correct, but you're making a mistake in evaluating the FFT output during your 510 kHz test. Good Luck, [-Rick-]
Hi, In fact I don't used a software FFT. I use an Altera FGPA FFT IP... I post on dsp forum because this is a signal processing problem... For my picket fence problem, I read that I must send to the FFT, my 256 samples and "sometimes" less samples and others at zero But how many times in time I don't send all my samples or my samples + zeros, and how many zeros must I add ? for my 510 kHz problem, it's a reset problem, if I reset a long time I d'ont have my stranger 2 frequencies bins... I think the IP core need a synchronous reset with a minimum time .... thanks
