Hi, I am trying to simulate the GSM physical layer and have a simple question regarding GMSK modulation: I am trying to implement the GMSK modulator using the quadrature baseband method outlined in: http://www.emc.york.ac.uk/reports/linkpcp/appD.pdf which states : NRZ sequence -> Gaussian filter convolution -> Integration -> I/Q decomposition -> Modulation. However, i have checked several other posts on this forum such as: http://www.dsprelated.com/showmessage/45749/1.php and people say that before integrating, I should express the convolved sequence as a phase rotation in radians and afterwards raise to the exp(j*phi) to get the complex I & Q signals. I doubt that these two methods give out the same result. Which one should be used for a GSM simulation ? Thank you in advance, John
GMSK Question
Started by ●February 13, 2007
Reply by ●February 13, 20072007-02-13
On Feb 13, 12:29 pm, "ik303" <john.kon...@gmail.com> wrote:> Hi, > > I am trying to simulate the GSM physical layer and have a simple question > regarding GMSK modulation: > > I am trying to implement the GMSK modulator using the quadrature baseband > method outlined in:http://www.emc.york.ac.uk/reports/linkpcp/appD.pdf > which states : NRZ sequence -> Gaussian filter convolution -> Integration > -> I/Q decomposition -> Modulation. > > However, i have checked several other posts on this forum such as:http://www.dsprelated.com/showmessage/45749/1.php > and people say that before integrating, I should express the convolved > sequence as a phase rotation in radians and afterwards raise to the > exp(j*phi) to get the complex I & Q signals. > > I doubt that these two methods give out the same result. Which one should > be used for a GSM simulation ? > > Thank you in advance, > JohnThe two references you cite describe exactly the same process. All they're referring to with "expressing the sequence as a phase rotation" is scaling the Gaussian filter output (or the coefficients of the filter itself) such that when you pass them through your integrator, a single Gaussian pulse will integrate to a value of pi/2. You then take the cosine and sine of these quantities to get your I and Q channels, then you go on to the modulator. So, either way will work. Jason
Reply by ●February 14, 20072007-02-14
Reply by ●July 13, 20102010-07-13
