Frequency Sweep Sonar System
Started by Nicholas Kinar ●February 13, 2007
Fred,
> > There's a very good reason that FMCW won't work for sonar although it may > work in air. Volume Reverberation! > At short range the receiver will be flooded with volume reverberation > signal. So, how to get the nice mixing of target and near-field cross > coupling? Very tough to do. Likely not possible. > > It is very common for pulsed CW sonar to be reverberation limited at the > receiver for short range targets. After a time the volume reverberation has > decayed to a point where the receiver becomes noise-limited. Of course, > this is for a broadband receiver. But, isn't that what you'd use for FMCW? > If the receiver has a filter bank or FFT then you expect noise limited > performance except around zero doppler. If the target isn't moving then > that's where it will be and you're back to being reverberation limited. (By > "limited", I mean the "noise" floor in the channel is determined by this > component and determines the necessary signal level for detection). >
This is really insightful. I would have never thought of this if I was designing a sonar system to be used under the water. However, the system that I am designing is to be used in determining the distance to the sea surface. It is a sonar used to be operated in the air medium. Nicholas
The sonar system that I am designing is similar to your own, Vladimir.
I am actually using the FMCW sweep to determine distance to the water
surface.  It is an air-coupled sonar that is operated in the air medium.
Your solution of using analog mixing seems to be very good.  But I
wonder (as academic problem) if this could be done completely using DSP.
Nicholas
Nicholas Kinar wrote:
> The sonar system that I am designing is similar to your own, Vladimir. > I am actually using the FMCW sweep to determine distance to the water > surface. It is an air-coupled sonar that is operated in the air medium.
The other problem is the high attenuation of the ultrasound in the air. For the moderately high frequencies (about 40kHz) the max. operating distance will be at the order of several meters.
> Your solution of using analog mixing seems to be very good. But I > wonder (as academic problem) if this could be done completely using DSP.
Certainly it can be done with the DSP. However there is no need to use the heavy weight solutions for that problem. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
> The other problem is the high attenuation of the ultrasound in the air. > For the moderately high frequencies (about 40kHz) the max. operating > distance will be at the order of several meters. >
The system is intended for application over distances on the order of several meters, so this is not a problem. My center frequency is ~30 kHz. I have been trying the signal processing with a test system. I have two transducers set up above a large piece of plywood. The signal is produced in MATLAB and converted to analog with a DAC. The signal is sampled at 96 kHz with ADC. I can get a reflection, but there appears to be crosstalk. Nicholas
Most active sonar systems have a gain control mechanism. One such
method is Time Varying Gain (TVG), where the gain is adjusted in a
fixed fashion over time - the signals are compensated later on for the
gain effect. Another alternative is to blank the receive hydrophones
to reduce the received reverberation/transmit leakage.
Either of these mechanisms is going to complicate the sonar circuitry.
Good luck.
Cheers,
Dave
In article <1171553917.740214.109420@m58g2000cwm.googlegroups.com>,
david@array.ca says...
> Most active sonar systems have a gain control mechanism. One such > method is Time Varying Gain (TVG), where the gain is adjusted in a > fixed fashion over time - the signals are compensated later on for the > gain effect. Another alternative is to blank the receive hydrophones > to reduce the received reverberation/transmit leakage. > > Either of these mechanisms is going to complicate the sonar circuitry. > > Good luck. > Cheers, > Dave > >
Thanks, Dave. I'll have to take this into consideration when designing the prototype system. Once again, thank you! Nicholas
On Feb 15, 6:12 pm, Nicholas Kinar <n.ki...@usask.ca> wrote:
> In article <1171553917.740214.109...@m58g2000cwm.googlegroups.com>, > d...@array.ca says... > > > Most active sonar systems have a gain control mechanism. One such > > method is Time Varying Gain (TVG), where the gain is adjusted in a > > fixed fashion over time - the signals are compensated later on for the > > gain effect. Another alternative is to blank the receive hydrophones > > to reduce the received reverberation/transmit leakage. > > > Either of these mechanisms is going to complicate the sonar circuitry. > > > Good luck. > > Cheers, > > Dave > > Thanks, Dave. I'll have to take this into consideration when designing > the prototype system. Once again, thank you! > > Nicholas
CWFM is used in simple radars and sonars because the output power - can- be kept constant, avoiding the cost of gain varying amplifiers and allowing lower peak power by measuring returned frequency difference over a longer time interval. See an example: http://www.st-andrews.ac.uk/~jcgl/Scots_Guide/RadCom/part15/page2.html for graphs and discussion. The received signal is mixed with the transmitted signal to produce the difference frequency where frequency is proportional to distance. Transmitter crosstalk is DC term out of the mixer and can be filtered out. Dale B. Dalrymple http://dbdimages.com
