I'm trying to implement the LED exercise at http://dsptute.blogspot.com on a TMS320C6713GDP DSK kit. The Simulink drawing (led.mdl) is straightforward enough just a constant 6 input to a C6713 DSK LED. I've used the C6713 diagnostic utility to confirm that the DSK kit is properly connected to the computer and the power source. But I can't for the life of me figure out how to properly configure everything. I go to the Simulation menu in the led.mdl window and change from Normal to External. I go to the Simulation menu in led.mdl, select Configuration Parameters, and go to Real-Time Workshop. I change the system target file to ti_c6000.tlc . I go to the Solver part of the Configuration Parameters window and change the fixed step size from auto to .2. The Build button I'm supposed to get does not exist - a Generate Code button is there instead. So I click on the Generate Code button and get the following error message in the Simulink window: "Error building Real-Time Workshop target for block diagram 'led'. MATLAB error message: Error using ==> callMakeHook.p>callMakeHook The call to ti_c6000_make_rtw_hook, during the before_tlc hook generated the following error: Error using ==> checkModelAndSystem_DSPtarget Error using ==> getTargetInfo The model must have a C6000 Target Preferences block. The build process will terminate as a result." I get the following error message in the MATLAB window: ### Generating code into build directory: . . . dskprojects\simulink1\led_c6000_rtw security reasons> Error executing m-file getIRInfo_C6000DSP ... Error using ==> getTargetInfo The model must have a C6000 Target Preferences block. Using the Incremental Build command in led.mdl yields the same error messages. Using the "Connect To Target" command under the Simulation menu in led.mdl yields the following Simulink error: Current Real-Time Workshop target for model 'led' is either not configured for or does not support external mode. In Interface page of the Real-Time Workshop page of Configuration Parameters dialog, select Interface option to be "External Mode" to enable external mode for targets that support it. and the same MATLAB window error message I was getting before. This is so FRUSTRATING! So close, and yet so far!
HELP! How do I configure Simulink to recognize the target DSP?
Started by ●February 14, 2007
