I have implemented a Viterbi soft decision (1/2 k=7) for a BFSK modulation. I need to know the minimum level deeper into the trellis to get symbol. In a book, i read something about a good value is 4 or 5 times the constraint lenght. Now, for example, after 32 levels (or states) i get the first symbol, but then o have a delay of 32 bits. Can i get a good measure of metric after 8 or 16 states, or the optimum is to wait 32 states?
Viterbi Soft Decision
Started by ●February 15, 2007
Reply by ●February 15, 20072007-02-15
JAlbertoDJ wrote:> I have implemented a Viterbi soft decision (1/2 k=7) for a BFSK > modulation.Great.> I need to know the minimum level deeper into the trellis to get symbol.The deeper - the better.> In a book, i read something about a good value is 4 or 5 times the > constraint lenght.It depends. The higher is the code rate, the deeper you have to dig into the trellis. For r=1/2, somewhere 5...7 x constraint length is a good compromise value.> Now, for example, after 32 levels (or states) i get the first symbol, but > then o have a delay of 32 bits.Yes, of course.> Can i get a good measure of metric after 8 or 16 states, or the optimum is > to wait 32 states?The optimum is to wait for an infinite number of states. You are trading off the delay for the efficiency of the code. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●February 16, 20072007-02-16
Ok, then you advised me 32 bits of delay (4 characters aprox.)?? The software is for ionospheric communications.
And when you says, for r=1/2, somewhere 5...7 x constraint length is a good compromise value, you refer to Data Input Sequence or Received Sequence? For example, I have this message to send: 10100101 (8 bits) Data input then, i code data input and get coded sequence for r=1/2: 1100110111100100 (16 bits) Data coded 5...7 x constraint length is a good compromise value for data coded or for input data??? thank you
JAlbertoDJ wrote:> Ok, then you advised me 32 bits of delay (4 characters aprox.)?? > The software is for ionospheric communications.I advise you to seek for professional advice. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Ok, but my software is for radioamateur communications, in others words, for hobbie. And i passed in this forum for learning and share knowledge, not for advertising free.
JAlbertoDJ wrote:> Ok, but my software is for radioamateur communications, in others words, > for hobbie. And i passed in this forum for learning and share knowledge, > not for advertising free. >The cheese is for free only in the two kinds of places: mouse traps or trash bins. VLV
On Feb 16, 6:54 am, "JAlbertoDJ" <nietoro...@yahoo.es> wrote:> And when you says, for r=1/2, somewhere 5...7 x constraint length is a > good compromise value, you refer to Data Input Sequence or Received > Sequence? > > For example, I have this message to send: > > 10100101 (8 bits) Data input > > then, i code data input and get coded sequence for r=1/2: > > 1100110111100100 (16 bits) Data coded > > 5...7 x constraint length is a good compromise value for data coded or for > input data??? > > thank youThe traceback depth is counted in units of coded symbols. In your case a coded symbol is a pair of bits exiting the encoder, produced by one information bit entering the encoder. If your decoder has a delay of 5*K coded symbols, that corresponds to 5*K information bits. John
