It is well known that the class D audio amplifiers do have the severe nonlinear distortion problems. This happens due to the fundamental properties of the PWM process, as well as due to the non-idealities of the real amplifier. The perception of those distortions is quite different from that of the distortions of an analog amp. Due to the sampled nature of the PWM system, the efficiency of the negative feedback is very limited. The HiFi quality PWM amp implies operating at the switch clock rate about 1 MHz. If the clock is running that high, the efficiency of the switch is going to be low, and even lower than that of the classic linear amp. Also, the EMC is going to be a hell of a problem. Do you know of someone who did a good analysis of the problem? Can you suggest a good reading or discussion on this topic? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Class D audio amplifier distortion
Started by ●February 19, 2007
Reply by ●February 19, 20072007-02-19
Vladimir Vassilevsky wrote:> It is well known that the class D audio amplifiers do have the severe > nonlinear distortion problems. This happens due to the fundamental > properties of the PWM process, as well as due to the non-idealities of > the real amplifier. The perception of those distortions is quite > different from that of the distortions of an analog amp. Due to the > sampled nature of the PWM system, the efficiency of the negative > feedback is very limited. The HiFi quality PWM amp implies operating at > the switch clock rate about 1 MHz. If the clock is running that high, > the efficiency of the switch is going to be low, and even lower than > that of the classic linear amp.This may have been true 10 years ago. In the mean time most audio amplifiers made for professional usage use PWM or related technologies to deliver immensely high power in extremly small and light weight housings (e.g. 2 x 1500W in 2HE housing). The THD figures may be a bit higher than good hifi amplifiers with much less power but are usually not higher than 0.1% which seems to be good enough for most purposes.> Also, the EMC is going to be a hell of a problem.I don't think so since otherwise they would not be allowed to sell their stuff, at least in Europe (due to the required CE label).> Do you know of someone who did a good analysis of the problem?May be you can find something in the white paper sections of the pro amplifier producers (Crown, QSC, EV, KME, Peavey, Camco, Dynacord).> Can you suggest a good reading or discussion on this topic?Try the NG rec.audio.pro bye Andreas -- Andreas H�nnebeck | email: acmh@gmx.de ----- privat ---- | www : http://www.huennebeck-online.de Fax/Anrufbeantworter: 0721/151-284301 GPG-Key: http://www.huennebeck-online.de/public_keys/andreas.asc PGP-Key: http://www.huennebeck-online.de/public_keys/pgp_andreas.asc
Andreas Huennebeck wrote:> Vladimir Vassilevsky wrote: > >>It is well known that the class D audio amplifiers do have the severe >>nonlinear distortion problems. This happens due to the fundamental >>properties of the PWM process, as well as due to the non-idealities of >>the real amplifier. The perception of those distortions is quite >>different from that of the distortions of an analog amp. Due to the >>sampled nature of the PWM system, the efficiency of the negative >>feedback is very limited. The HiFi quality PWM amp implies operating at >>the switch clock rate about 1 MHz. If the clock is running that high, >>the efficiency of the switch is going to be low, and even lower than >>that of the classic linear amp. > > > This may have been true 10 years ago.The fundamental problems do not change with the time. Today it was decided that the boombox quality is overweigthed by the obvious size/cost advantages, that's the only difference.> In the mean time most audio > amplifiers made for professional usage use PWM or related technologies > to deliver immensely high power in extremly small and light weight > housings (e.g. 2 x 1500W in 2HE housing). The THD figures may be > a bit higher than good hifi amplifiers with much less power but are > usually not higher than 0.1% which seems to be good enough for > most purposes.The 0.1% THD at 1kHz is a very poor figure indeed. And, besides, the distortions of the PWM amp can't be characterized by THD since many components of the garbage are not harmonically related to the fundamental.> > >>Also, the EMC is going to be a hell of a problem. > I don't think so since otherwise they would not be allowed to sell their > stuff, at least in Europe (due to the required CE label).:)))) Unfortunately, I have to deal with this kind of problem professionally. You will not be able to listen to the car radio if the PWM amp is on.> >>Do you know of someone who did a good analysis of the problem? > > May be you can find something in the white paper sections of > the pro amplifier producers (Crown, QSC, EV, KME, Peavey, > Camco, Dynacord).Been there, seen that. "We are the best of the best of the best" and such.>>Can you suggest a good reading or discussion on this topic? > Try the NG rec.audio.pro >Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky wrote:> > It is well known that the class D audio amplifiers do have the severe > nonlinear distortion problems. This happens due to the fundamental > properties of the PWM process, as well as due to the non-idealities of > the real amplifier. The perception of those distortions is quite > different from that of the distortions of an analog amp. Due to the > sampled nature of the PWM system, the efficiency of the negative > feedback is very limited. The HiFi quality PWM amp implies operating at > the switch clock rate about 1 MHz. If the clock is running that high, > the efficiency of the switch is going to be low, and even lower than > that of the classic linear amp. Also, the EMC is going to be a hell of a > problem.Though I do not have concrete data/evidence/knowledge on this area, I can throw my 2 cents in here. This last sentence really doesn't go with my experience --- a while ago we installed a car audio system for a friend; he had bought a PWM amplifier, and we were so profoundly surprised by how cold it was, that we had to open it; it had an array of little 2N29XX transistors (I forget the code of that casing --- was it TO95, perhaps? Anyway, the little ones, black plastic). I can tell you, we were throwing Watts at the speakers to the point where it would bother us of how loud it was, and you could touch the amplifier and *barely* notice that it was warm. Another thing --- what are those "fundamental properties" of the PWM process that you refer to? As far as I know, the unpleasant distorsion is mostly due to the Hysteresis (sp?) present in the low-pass filtering coil at the output; but that occurs only if it has a magnetic core --- if it is empty, then I don't see why it would have an excessive amount of inter-modulation distorsion (then again, I'm not sure how those are actually made). Carlos --
I concur with Vladimir. The argument for class D is power efficiency. There are several obvious problems with a switching amplifier. Assume that the transistors can not turn on and off instantaniously. The distortion created will not be simple harmonic distortion. Harmonic distortion is the least audible distortion, but the easiest to measure. You can assume that complex intermodulation products will be created and these are a bigger problem. You also have essentially no power supply rejection with a switching amplifier since the power supply is connected directly to the load. No amplifier has a power supply that is a perfect voltage source so imperfections in the supply are coupled to the loudspeaker. Another problem is that you have the switching frequency to get rid of. Since a loudspeaker is a low impedance load, the filtering is not trivial. The Cs & Ls used for this filtering are also less than ideal. For high performance systems, one might consider using a switching amplifier for sub woofers and woofers and use a linear amplifier for the higher frequency components. This gives you many of the power efficiency advantages with less audible consequences since the high frequency drivers need significantly less power. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote in news:NLiCh.59307$QU1.20798@newssvr22.news.prodigy.net:> > > Andreas Huennebeck wrote: >> Vladimir Vassilevsky wrote: >> >>>It is well known that the class D audio amplifiers do have the severe >>>nonlinear distortion problems. This happens due to the fundamental >>>properties of the PWM process, as well as due to the non-idealities >>>of the real amplifier. The perception of those distortions is quite >>>different from that of the distortions of an analog amp. Due to the >>>sampled nature of the PWM system, the efficiency of the negative >>>feedback is very limited. The HiFi quality PWM amp implies operating >>>at the switch clock rate about 1 MHz. If the clock is running that >>>high, the efficiency of the switch is going to be low, and even lower >>>than that of the classic linear amp. >> >> >> This may have been true 10 years ago. > > The fundamental problems do not change with the time. Today it was > decided that the boombox quality is overweigthed by the obvious > size/cost advantages, that's the only difference. > >> In the mean time most audio >> amplifiers made for professional usage use PWM or related >> technologies to deliver immensely high power in extremly small and >> light weight housings (e.g. 2 x 1500W in 2HE housing). The THD >> figures may be a bit higher than good hifi amplifiers with much less >> power but are usually not higher than 0.1% which seems to be good >> enough for most purposes. > > The 0.1% THD at 1kHz is a very poor figure indeed. And, besides, the > distortions of the PWM amp can't be characterized by THD since many > components of the garbage are not harmonically related to the > fundamental. > > >> >> >>>Also, the EMC is going to be a hell of a problem. >> I don't think so since otherwise they would not be allowed to sell >> their stuff, at least in Europe (due to the required CE label). > >:)))) > Unfortunately, I have to deal with this kind of problem > professionally. You will not be able to listen to the car radio if the > PWM amp is on. > >> >>>Do you know of someone who did a good analysis of the problem? >> >> May be you can find something in the white paper sections of >> the pro amplifier producers (Crown, QSC, EV, KME, Peavey, >> Camco, Dynacord). > > Been there, seen that. "We are the best of the best of the best" and > such. > >>>Can you suggest a good reading or discussion on this topic? >> Try the NG rec.audio.pro >> > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.com >
Carlos Moreno wrote:>> It is well known that the class D audio amplifiers do have the severe >> nonlinear distortion problems.[...]> I can tell you, we were throwing Watts at the speakers to the point > where it would bother us of how loud it was, and you could touch the > amplifier and *barely* notice that it was warm.I have the results of the real measurements on the linear and class D amps, and it is not all as good as claimed by the D class supporters.> Another thing --- what are those "fundamental properties" of the > PWM process that you refer to?Basically, if the audio signal is mixed with the triangular wave on the comparator, it will produce all kinds of intermod products. Some of those products are falling into the audible band. This effect can be cured by the sophisticated DSP processing, however it is fairly demanding computational task, thus it is cost prohibitive.> As far as I know, the unpleasant distorsion is mostly due to the > Hysteresis (sp?) present in the low-pass filtering coil at the > output;The nonlinearity of the L and C at the output is only one of the many problems of the class D. The output devices are not identical, the impedances are not identical, the switch timing is not identical and varying with the voltage/temperature.> but that occurs only if it has a magnetic core --- if it > is empty, then I don't see why it would have an excessive amount > of inter-modulation distorsion (then again, I'm not sure how those > are actually made).Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Al Clark wrote: [...]> For high performance systems, one might consider using a switching > amplifier for sub woofers and woofers and use a linear amplifier for the > higher frequency components. This gives you many of the power efficiency > advantages with less audible consequences since the high frequency > drivers need significantly less power.The elegant concept is sharing the common load between the switching amp and a small linear amp. The purpose of the linear amp is only to compensate the distortions of the switcher, hence the power of the linear amp can be quite small. So the total efficiency is determined by the switching amp. However this solution is cumbersome and the cost is too high for the consumer market. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky wrote:> > It is well known that the class D audio amplifiers do have the severe > nonlinear distortion problems. This happens due to the fundamental > properties of the PWM process, as well as due to the non-idealities of > the real amplifier. The perception of those distortions is quite > different from that of the distortions of an analog amp. Due to the > sampled nature of the PWM system, the efficiency of the negative > feedback is very limited. The HiFi quality PWM amp implies operating at > the switch clock rate about 1 MHz. If the clock is running that high, > the efficiency of the switch is going to be low, and even lower than > that of the classic linear amp. Also, the EMC is going to be a hell of a > problem. > > Do you know of someone who did a good analysis of the problem? > Can you suggest a good reading or discussion on this topic?The first class D amp I saw was the audio output of the world's first all transistor (apart from the tube) colour TV - the Thorn 2000. That was about 1967. It used only a few transistors, and was obviously designed for low cost in a TV, rather than hi-fi. However, a pair of those simple amps, with quite a modest switching frequency, sounded better than many quite expensive stereo amps sold in the Hi-Fi market. Its seems when done with care, pretty basic class-D can sound very good. Steve
Steve Underwood wrote:>> It is well known that the class D audio amplifiers do have the severe >> nonlinear distortion problems.> The first class D amp I saw was the audio output of the world's first > all transistor (apart from the tube) colour TV - the Thorn 2000. That > was about 1967.The first listeners of the Edison's phonograph were quite exited about its sound also :) VLV
On Mon, 19 Feb 2007 15:12:45 +0000, Vladimir Vassilevsky wrote:> This happens due to the fundamental > properties of the PWM process, as well as due to the non-idealities of > the real amplifier. The perception of those distortions is quite > different from that of the distortions of an analog amp. Due to the > sampled nature of the PWM system, the efficiency of the negative > feedback is very limited. The HiFi quality PWM amp implies operating at > the switch clock rate about 1 MHz.I don't belive that most of the currently available class D amplifiers are strictly PWM at all. My understanding was that at least some of them were essentially sigma-delta modulators: could easily be wrong, though -- it's not my field. I can say that I've heard demos of experimental versions of both B&O's ICEpower amps and something by Sony the name of which escapes me, and they seemed quite fine. Certainly HiFi quality. I hadn't heard that any of the currently available class D amps were switching at much more than 500kHz, but maybe they are, now. -- Andrew
