Hi, I have implemented the Audio Mixer, which will mix three Audio Signal. I have done implementation using MATLAB. I am getting the Mixed Signal. I performed listening test on it. It sounds good. I want some quality criteria to be defined to validate Mixed Output signal. Your Input will help me. Thanks in Advance, Regards, Sri Kant
measuring the quality of mixer
Started by ●February 20, 2007
Reply by ●February 20, 20072007-02-20
srikk wrote:> Hi, > I have implemented the Audio Mixer, which will mix three Audio Signal. I > have done implementation using MATLAB. I am getting the Mixed Signal. I > performed listening test on it. It sounds good. I want some quality > criteria to be defined to validate Mixed Output signal. Your Input will > help me.As a first calibration step, put in a single sine and determine what frequencies come out and at what levels. Then mix three sines whose periods are not related by simple fractions and again examine the output for artifacts. The fewer and the weaker, the better. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
