I need a cross correlation, which is circular along teta-axis and linear along ro-axis XC(H', R') = Σ Σ F(p + H', teta + R'). G(p,teta ) I have tried several methods but without satisfactory results. Also, I have used the function "imfilter", which does a circular correlation but the result is always the same: bad. I know that teta-axis-circular and p-axis-linear cross-correlation can readily be achieved by zero-padding only the p-axis direction and performing a circular cross-correlation with an FFT- based algorithm but I don�t know how.I think i Do bad the zero padding but I�m not sure. I would be very grateful if somebody could help me. Thank you
circular cross correlation
Started by ●February 26, 2007
Reply by ●February 26, 20072007-02-26
On Feb 26, 6:00 am, "jasg" <jorgesanchezgar...@hotmail.com> wrote:> I need a cross correlation, which is circular along teta-axis and linear > along ro-axis > XC(H', R') =3D =CE=A3 =CE=A3 F(p + H', teta + R'). G(p,tet=a ) Sorry, I don't understand what you are trying to do. Are you trying to generate a stochastic vector with a certain correlation property? Or are you trying to make a filter with a certain spectrum?> > I have tried several methods but without satisfactory results. Also, I > have used the function "imfilter", which does a circular correlation butSorry, I don't know what imfilter is. Julius
I am working with image registration. I work with images(matrix, no with vectors). For the correlation I use two matrix (images) in polar co-ordinates (r,teta). My problem is that I need to do a two-dimensional cross correlation, which it is circular along teta-axis and linear along r-axis. Imfilter is a function of Matlab that do a circular cross correlation. Jasg
