DSD 1796
Started by Himlam8484 ●February 27, 2007
Hi People,
I intend to design a DA converter by using the IC DSD1796, but i have
some problems with them.I do not know if i can connect DGND with AGND
or not. With this IC, if not use a signal controller, can it run? If
it does not need a controller, what can i connect control pin?
I use PCM mode.
Did anyone work with this IC, Please make me clearly,
I am looking hearing from everyone soon,
Him Lam
Himlam8484 wrote:
> Hi People, > > > I intend to design a DA converter by using the IC DSD1796, but i have > some problems with them.I do not know if i can connect DGND with AGND > or not. With this IC, if not use a signal controller, can it run? If > it does not need a controller, what can i connect control pin? > > I use PCM mode. > Did anyone work with this IC, Please make me clearly, > > I am looking hearing from everyone soon,
The DSD1796 _is_ a DtoA converter. Do you have the application notes and data sheet? Denon specified the part and Burr-Brown makes it. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
On Feb 28, 10:02 am, Jerry Avins <j...@ieee.org> wrote:
> Himlam8484 wrote: > > Hi People, > > > I intend to design a DA converter by using the IC DSD1796, but i have > > some problems with them.I do not know if i can connect DGND with AGND > > or not. With this IC, if not use a signal controller, can it run? If > > it does not need a controller, what can i connect control pin? > > > I use PCM mode. > > Did anyone work with this IC, Please make me clearly, > > > I am looking hearing from everyone soon, > > The DSD1796 _is_ a DtoA converter. Do you have the application notes and > data sheet? Denon specified the part and Burr-Brown makes it. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=
=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF Hi Jerry, i would like to ask that with the default value, can Ic work well??? have a nice day, Him Lam
Himlam8484 wrote:
> On Feb 28, 10:02 am, Jerry Avins <j...@ieee.org> wrote: >> Himlam8484 wrote: >>> Hi People, >>> I intend to design a DA converter by using the IC DSD1796, but i have >>> some problems with them.I do not know if i can connect DGND with AGND >>> or not. With this IC, if not use a signal controller, can it run? If >>> it does not need a controller, what can i connect control pin? >>> I use PCM mode. >>> Did anyone work with this IC, Please make me clearly, >>> I am looking hearing from everyone soon, >> The DSD1796 _is_ a DtoA converter. Do you have the application notes and >> data sheet? Denon specified the part and Burr-Brown makes it.
> Hi Jerry, > > i would like to ask that with the default value, can Ic work well???
Default value of what? In any case, I'd need to study the data sheet, ans I don't have it. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
hi Jerry,
I read datasheet, but i am ashamed of myself because i do not
understand it clearly,
I did not use english to communicate in my country, therefor i
sometimes know some things unclearly.
If i do not use a control signals, can IC work? please tell me with my
stupid question.
Him Lam
No ask, no understand
Himlam8484 wrote:
> hi Jerry, > > I read datasheet, but i am ashamed of myself because i do not > understand it clearly, > I did not use english to communicate in my country, therefor i > sometimes know some things unclearly. > > If i do not use a control signals, can IC work? please tell me with my > stupid question.
If the data sheet is on the web, tell me where and I will try to interpret it for you. I'm sorry about your problem with English, but we can try to work around it. You actually do very well when you can choose the words. Understanding the words other people use must be more difficult. I know it is for me. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
hi,
Here is the link to download datasheet
http://www.alldatasheet.com/datasheet-pdf/pdf/85355/TI/DSD1796.html
you can use any words you can. I can undersatnd them. I do only not
understand some electronic terms in datasheet. You can clarify to me
the part default value of this IC. I need information from this part.
Thank for supporting,
Him Lam
Himlam8484 wrote:
> hi, > > Here is the link to download datasheet > http://www.alldatasheet.com/datasheet-pdf/pdf/85355/TI/DSD1796.html > you can use any words you can. I can undersatnd them. I do only not > understand some electronic terms in datasheet. You can clarify to me > the part default value of this IC. I need information from this part.
I need time to look at in detail, but now I have errands to do. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
Jerry Avins wrote:
> Himlam8484 wrote: >> hi, >> >> Here is the link to download datasheet
... Himlam, There are 53 pages. I can give you some quick answers. DGND and AGND are the grounds for the digital and analog portions of the chip circuitry. They need to be connected together somewhere, but to minimize noise in the audio, they should be connected only at one point and there should be no signal or power return paths in the connection. If by signal controller, you mean some device that can send commands via an SPI serial link, then a signal controller is needed. I'm sure you have more questions. If you ask in detail, I'll try to find the answers. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
On Mar 9, 12:07 am, Jerry Avins <j...@ieee.org> wrote:
> Jerry Avins wrote: > > Himlam8484 wrote: > >> hi, > > >> Here is the link to download datasheet > > ... > > Himlam, > > There are 53 pages. I can give you some quick answers. > > DGND and AGND are the grounds for the digital and analog portions of the > chip circuitry. They need to be connected together somewhere, but to > minimize noise in the audio, they should be connected only at one point > and there should be no signal or power return paths in the connection. > > If by signal controller, you mean some device that can send commands via > an SPI serial link, then a signal controller is needed. > > I'm sure you have more questions. If you ask in detail, I'll try to find > the answers. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=
=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF Jerry, I have just made the DA convert board again, I used your advice. There is a thing i want to ask you that if i do not need to send commands via serial port, will not i use a control system? with this case, can IC work ? Him Lam
