Dear comp.dsp, I am going to try to learn a bit more about the wireless channel (specifically using OFDM) by first creating a set of symbols and perform a transmit and receive. It is a simple begining I want to make, and I will probably use GNU Octave and, later, when I do know the basics, shift to IT++. My doubts are: 1. Let us say I am going to use just BPSK over OFDM. Then, I can level shift the BPSK to +1 and -1, divide it into blocks of Nfft each (where Nfft is the number of subcarriers), take ifft and prepend the cyclic prefix (don't know how much yet), add some Gaussian white noise, and retrieve the samples after doing an IFFT. Now, since I haven't assumed a multipath channel, I needn't really do channel estimation, as I know the point where the actual symbol starts. Is this assumption correct? 2. How do I simulate the fading? Is it simply using a Rayleigh random variable multiplying my samples before going through AWGN, for slow fading? 3. What would be the right way to estimate my channel, if I assume that the channel is a tapped-delay FIR filter? If I understand estimation theory correctly, the best way would be to use known pseudo- random sequence and do a least squares estimate, invert the channel response and obtain the equalized result. Is this correct? Thanks a lot! Kumar
Assumptions to be made while simulating for a wireless channel
Started by ●February 27, 2007
Reply by ●February 28, 20072007-02-28
On Feb 27, 10:09 pm, "Kumar Appaiah" <kumar.appa...@gmail.com> wrote:> Dear comp.dsp, > > I am going to try to learn a bit more about the wireless channel > (specifically using OFDM) by first creating a set of symbols and > perform a transmit and receive. It is a simple begining I want to > make, and I will probably use GNU Octave and, later, when I do know > the basics, shift to IT++. > > My doubts are: > > 1. Let us say I am going to use just BPSK over OFDM. Then, I can level > shift the BPSK to +1 and -1, divide it into blocks of Nfft each (where > Nfft is the number of subcarriers), take ifft and prepend the cyclic > prefix (don't know how much yet), add some Gaussian white noise, and > retrieve the samples after doing an IFFT. Now, since I haven't assumed > a multipath channel, I needn't really do channel estimation, as I know > the point where the actual symbol starts. Is this assumption correct?Right. If you don't simulate any channel dispersion and just have additive noise, there's nothing to equalize, except for maybe filtering the data to remove some of the noise if possible.> 2. How do I simulate the fading? Is it simply using a Rayleigh random > variable multiplying my samples before going through AWGN, for slow > fading?That's one way to do it.> 3. What would be the right way to estimate my channel, if I assume > that the channel is a tapped-delay FIR filter? If I understand > estimation theory correctly, the best way would be to use known pseudo- > random sequence and do a least squares estimate, invert the channel > response and obtain the equalized result. Is this correct?Again, that's one way to do it. You can use a number of different algorithms for making an equalizer, such as LMS or least squares. If the channel is non-time-varying and you have a model for it, then you can solve for a fixed optimal filter. However, this isn't practical (in practice you won't know the exact transfer function of the channel, and it will likely vary over time), so for a more realistic simulation, you should probably use some adaptive algorithm like LMS or recursive least-squares to estimate the channel's transfer function. One way of helping the filter to adapt to the channel is by using a training sequence of known symbols, such as a PN sequence, before you actually start transmitting data. After the training is complete, you would switch the filter to "decision-directed" mode, which uses the output of your demodulator as the filter's reference signal. Most adaptive filtering textbooks would have some sort of material on this topic. Jason
On Feb 28, 6:55 pm, cincy...@gmail.com wrote:> > 3. What would be the right way to estimate my channel, if I assume > > that the channel is a tapped-delay FIR filter? If I understand > > estimation theory correctly, the best way would be to use known pseudo- > > random sequence and do a least squares estimate, invert the channel > > response and obtain the equalized result. Is this correct? > > Again, that's one way to do it. You can use a number of different > algorithms for making an equalizer, such as LMS or least squares. If > the channel is non-time-varying and you have a model for it, then you > can solve for a fixed optimal filter. However, this isn't practical > (in practice you won't know the exact transfer function of the > channel, and it will likely vary over time), so for a more realistic > simulation, you should probably use some adaptive algorithm like LMS > or recursive least-squares to estimate the channel's transfer > function. One way of helping the filter to adapt to the channel is by > using a training sequence of known symbols, such as a PN sequence, > before you actually start transmitting data. After the training is > complete, you would switch the filter to "decision-directed" mode, > which uses the output of your demodulator as the filter's reference > signal. Most adaptive filtering textbooks would have some sort of > material on this topic.Thanks for the pointers. I shall move refer to some material related to this. I guess you are referring to the decision feeedback equalizer. One more thing. For a time varying FIR channel, as you say, the coefficients vary with time with some correlation. So, would simulating channel which moves around (I mean varies statistically according to) a power delay profile be a good idea? Thanks. Kumar
