Quality PC Microphone
Started by Unknown ●March 4, 2007
Can someone recommend a source for a high quality PC microphone?
I'm looking for something a little better than the standard $10
BestBuy piece of junk.
Thanks,
John
OK. I just found some info. It looks as though the limiting factor
here is the sound card, so a quality mic really won't achieve much.
I guess the solution is a quality mic with a digital recorder. After
recording, transfer to the PC for analysis.
Any suggestions on a reasonably priced way of doing that?
Thanks,
John
jecottrell65@gmail.com wrote:
> Can someone recommend a source for a high quality PC microphone? > > I'm looking for something a little better than the standard $10 > BestBuy piece of junk.
You can get junk for a lot less than $10. Electrets are pretty good. most lapel mics used in live TV interview shows are electrets. Aside from the connector, what determines that a microphone is a PC microphone? If I knew what you want and why, I could probably recommend something. Frequency response? sensitivity? Directional pattern? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
> OK. I just found some info. It looks as though the limiting factor > here is the sound card, so a quality mic really won't achieve much. > > I guess the solution is a quality mic with a digital recorder. After > recording, transfer to the PC for analysis. > > Any suggestions on a reasonably priced way of doing that?
How about a better sound card? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
> OK. I just found some info. It looks as though the limiting factor > here is the sound card, so a quality mic really won't achieve much. > > I guess the solution is a quality mic with a digital recorder. After > recording, transfer to the PC for analysis. > > Any suggestions on a reasonably priced way of doing that? > > Thanks, > > John >
Is this for mobile (location) recording, or in studio/lab (where power supplies no problem)? If the latter, best combination is condenser mic (balanced output, usually via XLR connector) through a small mixer that can supply phantom power to the mic (some of the better semi-pro external (USB, Firewire) soundcards will also do that). Good to avoid direct mic-level inputs on cards internal to the PC. The electret suggestion can be useful for location recording (e.g. battery-powered mic, laptop, no mixer). The balanced output from the mic is essential to minimize noise, interference etc. Or even: use one of the new-generation USB microphones (e.g. Samson). I guess that could be one definition of a "PC microphone". Beyond that it all depends on what level of audio quality (dynrange, max SPL, bandwidth, response pattern, etc) you are looking for. Richard Dobson
Laptop..... (portable recording)
>Frequency response?
5-1000Hz
>sensitivity?
Best possible.... within reason. (sorry not more precise)
Omni Thanks, John
Yes.
> Or even: use one of the new-generation USB microphones (e.g. Samson). I > guess that could be one definition of a "PC microphone".
I just wandered across them. Thanks, John
> >> How about a better sound card? > > Laptop..... (portable recording) > >> Frequency response? > > 5-1000Hz
5 Hz will be difficult. 50 is more realistic. 20 is hard. All but specialty mics will go much higher than 1000. Will you need to filter? Consider a low sample rate to make the files small.
>> sensitivity? > > Best possible.... within reason. (sorry not more precise)
You should use an external preamp if you can, so enough signal to swamp the internal noise is all you need. Balanced low-impedance microphone for best noise immunity. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Jerry Avins wrote:
> jecottrell65@gmail.com wrote: > >> >>> How about a better sound card? >> >> >> Laptop..... (portable recording) >> >>> Frequency response? >> >> >> 5-1000Hz > > > 5 Hz will be difficult. 50 is more realistic. 20 is hard. All but > specialty mics will go much higher than 1000. Will you need to filter? > Consider a low sample rate to make the files small. >
The only device I know of that is specified to that low is the microflown: http://www.microflown.com It is a true particle velocity device (or rather, a whole family of devices); highly specialized, and rather more than $10. Richard Dobson
On Mar 5, 6:30 am, Richard Dobson <richarddob...@blueyonder.co.uk>
wrote:
> Jerry Avins wrote: > > jecottrel...@gmail.com wrote: > > >>> How about a better sound card? > > >> Laptop..... (portable recording) > > >>> Frequency response? > > >> 5-1000Hz > > > 5 Hz will be difficult. 50 is more realistic. 20 is hard. All but > > specialty mics will go much higher than 1000. Will you need to filter? > > Consider a low sample rate to make the files small. > > The only device I know of that is specified to that low is the microflown: > > http://www.microflown.com > > It is a true particle velocity device (or rather, a whole family of > devices); highly specialized, and rather more than $10. > > Richard Dobson
You need an external sound card - say M-Audio USB. Also you need a pre- amp and feed the signal(s) to the line input. You can use the Audio Buddy as a pre-amp for instance. F.
