HI , i am satish doing my MS. I need c programming code for audio signal compression. The code should be compatible to run on TMS320c55x platform. The software used for this is "code composer studio". Can any help me out fr getting the code for the above topic. Regards satish
code compoder studio 3.1 version for TMS320c55x DSK board
Started by ●March 5, 2007
Reply by ●March 6, 20072007-03-06
On Mar 5, 2:36 pm, "satish" <prakash.na...@gmail.com> wrote:> HI , i am satish doing my MS. I need c programming code for audio > signal compression. The code should be compatible to run on > TMS320c55x > platform. The software used for this is "code composer studio". Can > any help me out fr getting the code for the above topic.You're going to have to be more specific. What sort of compression? What sort of input signal? You should try running through the CCS tutorials. They have some audio processing code for the DSK (at least they do for the 6713 DSK) that may give you a framework to build on, and then you can google for some compression code. Anything that is ANSI C (or C++) will probably work with the TI compiler; it's pretty compliant. Also look at TI's free libraries and algo framework. Cheers! --M
