I was given a continous signal x(t) = 1.272*cos(2*pi*50*t)−0.424*cos(2*p*150*t)+0.255*cos(2*pi*250*t) and I generated discrete signal {x(n)}, 0 <=n <=256. Sampling frequnecy is fs = 1000 Hz. Now I need to design a Discrete low pass filter (Butterworth ili Chebishev)that will attenuate 150 Hz signal componentat most 1dB and attenuate 250 Hz signal component not more than 40 dB. I appreciate your help, Marie
IIR Filter Design
Started by ●March 7, 2007
Reply by ●March 7, 20072007-03-07
On 7 Mar, 13:39, "jerseygirl" <odmenet...@yahoo.com> wrote:> I was given a continous signal > > x(t) = > 1.272*cos(2*pi*50*t)-0.424*cos(2*p*150*t)+0.255*cos(2*pi*250*t) > and I generated discrete signal {x(n)}, 0 <=n <=256. Sampling frequnecy is > fs = 1000 Hz. > > Now I need to design a Discrete low pass filter (Butterworth ili > Chebishev)that will attenuate 150 Hz signal componentat most 1dB and > attenuate 250 Hz signal component not more than 40 dB. > > I appreciate your help,Homework? There ought to be a recipe for this in your textbook. The general recipe is as follows: 1) Set up the specification (attenuation or ripple, corner frequencies) in discrete time domain. 2) Pre-warp these to analog domain 3) Determine the filter order from the analog domain specification 4) Compute the poles and zeros in analog domain 5) Use the bilinear transform on each 2nd or 1st order section to transfer the filter back to discrete time domain 6) Use a frequency transform to get your final filter. Rune
On Mar 7, 7:39 am, "jerseygirl" <odmenet...@yahoo.com> wrote:> I was given a continous signal > > x(t) =3D > 1.272*cos(2*pi*50*t)=E2=88=920.424*cos(2*p*150*t)+0.255*cos(2*pi*250*t) > and I generated discrete signal {x(n)}, 0 <=3Dn <=3D256. Sampling frequne=cy is> fs =3D 1000 Hz. > > Now I need to design a Discrete low pass filter (Butterworth ili > Chebishev)that will attenuate 150 Hz signal componentat most 1dB and > attenuate 250 Hz signal component not more than 40 dB. > > I appreciate your help, > > MarieThose are strange filter specifications. Usually, a Butterworth filter is specified in terms of its 3-dB point (the passband edge); the 1-dB value you give sounds like something that you would use for a type-I Chebyshev filter (maximum passband ripple specification). And, I think you probably mean "attenuate a 250 Hz signal component by at least 40 dB", as the stopband behavior is usually given in a "minimum attenuation" number. In any event, as Rune said, this should be covered in most textbooks out there. If you care, there's a particularly good treatment (IMHO) of this topic in "A Course in Digital Signal Processing" by Porat. Jason
On 7 Mar, 14:19, cincy...@gmail.com wrote:> On Mar 7, 7:39 am, "jerseygirl" <odmenet...@yahoo.com> wrote: > > > I was given a continous signal > > > x(t) =3D > > 1.272*cos(2*pi*50*t)=E2=88=920.424*cos(2*p*150*t)+0.255*cos(2*pi*250*t) > > and I generated discrete signal {x(n)}, 0 <=3Dn <=3D256. Sampling frequ=necy is> > fs =3D 1000 Hz. > > > Now I need to design a Discrete low pass filter (Butterworth ili > > Chebishev)that will =C2=A0attenuate 150 Hz signal componentat most 1dB =and> > attenuate 250 Hz signal component not more than 40 dB. > > > I appreciate your help, > > > Marie > > Those are strange filter specifications. Usually, a Butterworth filter > is specified in terms of its 3-dB point (the passband edge); the 1-dB > value you give sounds like something that you would use for a type-I > Chebyshev filter (maximum passband ripple specification).It is perfectly possible to design a Butterworth filter with this sort of ripple. It only means that the 3 dB point is somewhere in the transition band, not on the passband corner frequency.> And, I think > you probably mean "attenuate a 250 Hz signal component by at least 40 > dB", as the stopband behavior is usually given in a "minimum > attenuation" number.You are right, but provided the OP cites the spec correctly, it is a perfectly possible -- if maybe a bit unreasonable -- specification. The one filter that meets the spec is the one that attenuates exactly 40 dB on the passband corner. Which might be the kind of devious twist I might give in a homework excercise... Rune
