In helping debug a QPSK receiver, I noticed that at the output of the matched filter the I and Q channels are delayed by different amounts. Is this what is called "I/Q imbalance"? I have always thought that it meant the I and Q mixers are not orthogonal to each other, or that the amplitudes are not the same. I would also love to hear about what may cause this phenomena. I thought that non-constant group delay may be the issue, but how does it effect the I and Q channels so that one is delayed versus the other? Thanks in advance, Julius
I / Q delay mismatch
Started by ●March 8, 2007
Reply by ●March 8, 20072007-03-08
Hi Julius, "julius" <juliusk@gmail.com> writes:> In helping debug a QPSK receiver, I noticed that at the output of the > matched filter the I and Q channels are delayed by different amounts. > Is this what is called "I/Q imbalance"? I have always thought that it > meant the I and Q mixers are not orthogonal to each other, or that the > amplitudes are not the same.Yes, I think that's true. I.e., I would not call this "I/Q imbalance." I/Q imbalance is memoryless.> I would also love to hear about what may cause this phenomena.Are you sure the problem is in the receiver? -- % Randy Yates % "I met someone who looks alot like you, %% Fuquay-Varina, NC % she does the things you do, %%% 919-577-9882 % but she is an IBM." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
On 8 Mar, 19:01, "julius" <juli...@gmail.com> wrote:> In helping debug a QPSK receiver, I noticed that at the output of the > matched filter the I and Q channels are delayed by different amounts. > Is this what is called "I/Q imbalance"? I have always thought that it > meant the I and Q mixers are not orthogonal to each other, or that the > amplitudes are not the same. > > I would also love to hear about what may cause this phenomena. I > thought that non-constant group delay may be the issue, but how does > it effect the I and Q channels so that one is delayed versus the > other?I don't have any experience with I/Q systems, but off the top of my head, I would agree that group delay might be the culprit. As you know, group delay is defined as g = -dphi/dw meaning that two different filters must have similar phase spectra in order to exhibit the same group delays. The only filters where that is guaranteed to happen, are symmetric FIR filters of the same length. Since you have two(?) matched filters, one for the I channel and one for the Q channel, these are almost certainly not symmetric FIR filters, and hence have different phase spectra, and so also different group delays. Provided this line of reasoning make some sense -- and I am not at all sure it does -- I would suggest appending all-pass filters on both channels with phase responses tailored to equalize the total phase responses of the two channels. My NOK 0.02. Rune
On Mar 8, 6:19 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote:> On 8 Mar, 19:01, "julius" <juli...@gmail.com> wrote: > > > In helping debug a QPSK receiver, I noticed that at the output of the > > matched filter the I and Q channels are delayed by different amounts. > > Is this what is called "I/Q imbalance"? I have always thought that it > > meant the I and Q mixers are not orthogonal to each other, or that the > > amplitudes are not the same. > > > I would also love to hear about what may cause this phenomena. I > > thought that non-constant group delay may be the issue, but how does > > it effect the I and Q channels so that one is delayed versus the > > other? > > Since you have two(?) matched filters, one > for the I channel and one for the Q channel, > these are almost certainly not symmetric > FIR filters, and hence have different > phase spectra, and so also different group > delays.I would imagine that if this is being in done in DSP, then the filters should be identical (and probably symmetric) FIRs; there's no reason that they should have been designed differently from each other. -- Oli
On Mar 8, 12:15 pm, Randy Yates <y...@ieee.org> wrote:> Are you sure the problem is in the receiver?Hi Randy, I was at first convinced that this can't be a problem at the receiver. But both TX and RX are direct- synthesis, no IF, so now I am puzzled! Thanks, Julius
On Mar 8, 12:19 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote:> I don't have any experience with I/Q systems, > but off the top of my head, I would agree that > group delay might be the culprit. > > As you know, group delay is defined as > > g = -dphi/dw > > meaning that two different filters must have > similar phase spectra in order to exhibit the > same group delays. The only filters where > that is guaranteed to happen, are symmetric > FIR filters of the same length. >Hi Rune, thanks for the reply. I thought about this, too. Let's say that we have x(t) = x_I(t) + j*x_Q(t) to represent the complex baseband. Now, we know that X_I(f) = even(X_f) and X_Q(f) = odd(X_f) are the appropriate Fourier transforms. Suppose now that I have a "channel" that is H(f) = \exp(j \phi(f)) to represent the delay terms. Then this will effect X_I(f) and X_Q(f) identically. So unfortunately this doesn't explain why the I and Q channels are delayed by different amounts. :-( Thanks, Julius
On Mar 8, 12:37 pm, "Oli Charlesworth" <c...@olifilth.co.uk> wrote:> > I would imagine that if this is being in done in DSP, then the filters > should be identical (and probably symmetric) FIRs; there's no reason > that they should have been designed differently from each other. > > -- > OliHi Oli, you are correct that this is done digitally, in Matlab actually. I just read the ADC output and did the mixing and match filtering in Matlab. I thought about the possible effect of jitter in the ADC, or when writing the data into the buffer for Matlab, but since this is the *modulated* version, then a delay will look rather obvious in the eye diagram, I thought. Thanks, Julius
"julius" <juliusk@gmail.com> wrote in message news:1173379347.923060.209270@c51g2000cwc.googlegroups.com...> On Mar 8, 12:19 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote: > >> I don't have any experience with I/Q systems, >> but off the top of my head, I would agree that >> group delay might be the culprit. >> >> As you know, group delay is defined as >> >> g = -dphi/dw >> >> meaning that two different filters must have >> similar phase spectra in order to exhibit the >> same group delays. The only filters where >> that is guaranteed to happen, are symmetric >> FIR filters of the same length. >> > > Hi Rune, thanks for the reply. I thought about this, too. > Let's say that we have x(t) = x_I(t) + j*x_Q(t) to represent > the complex baseband. > > Now, we know that X_I(f) = even(X_f) and X_Q(f) = odd(X_f) > are the appropriate Fourier transforms. > > Suppose now that I have a "channel" that is > H(f) = \exp(j \phi(f)) > to represent the delay terms. > > Then this will effect X_I(f) and X_Q(f) identically. So > unfortunately this doesn't explain why the I and Q channels > are delayed by different amounts. :-( > > Thanks, > JuliusIf the I and Q channels have different spectral content and if the channel isn't linear phase (constant delay) then the channels might be delayed differently. Not that this is what's going on ...... That is, if the group delay isn't flat. Fred
julius wrote:> In helping debug a QPSK receiver, I noticed that at the output of the > matched filter the I and Q channels are delayed by different amounts. > Is this what is called "I/Q imbalance"?It is called the screwed up PLL.> I have always thought that it > meant the I and Q mixers are not orthogonal to each other, or that the > amplitudes are not the same.There is no need to think. Extra knowledge is only harmfull.> I would also love to hear about what may cause this phenomena.As usual: lousy programming, bad or broken hardware or both.> I > thought that non-constant group delay may be the issue, but how does > it effect the I and Q channels so that one is delayed versus the > other?Don't think about that. Fix the PLL first. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Mar 8, 1:01 pm, "julius" <juli...@gmail.com> wrote:> In helping debug a QPSK receiver, I noticed that at the output of the > matched filter the I and Q channels are delayed by different amounts. > Is this what is called "I/Q imbalance"? I have always thought that it > meant the I and Q mixers are not orthogonal to each other, or that the > amplitudes are not the same. > > I would also love to hear about what may cause this phenomena. I > thought that non-constant group delay may be the issue, but how does > it effect the I and Q channels so that one is delayed versus the > other? > > Thanks in advance, > JuliusThis sounds like an implementation error of some kind. Gain and phase imbalance don't cause delay differences. How much delay is there? Could it be the transmitter is modulating I(t) and Q(t-d) or vice versa? John
