Hi all, I am rather new to this and would appreciate if someone would kindly enlighten me on this: My pilots symbols are inserted into a set of subcarriers (comb type). I've seen the MMSE estimate of the FFT of the channel coefficients given as: H_mmse = R_HHls(R_HlsHls + sigma^2(XX^h)^-1)^-1 Hls where Hls is the channel estimates from the pilot symbols using the least square method. H is the FFT of the channel coefficients and R_HHls denotes the cross correlation matrix of H and Hls. sigma^2 is the noise variance. h denotes hermittian. I would like to know as wiener filter minimizes the MSE, if I had used: R_HlsHls(R_HlsHls + sigma^2(XX^h)^-1)^-1 Hls instead, meaning I only have the channel estimates at the pilot symbols, can i use any low pass filter to interpolate (using resample function in matlab)? Will it result in MMSE? Or can any one kindly share with me how to construct the wiener filter? Why i did this is because the previous expression for H_mmse did not give me good performance. In fact interpolating using a separate low pass filter gives me better performance. Any insights/comments would be very much appreciated. Thank you Gladys
OFDM Channel Estimation Wiener Filtering
Started by ●March 9, 2007
