Hello. I recently install Code Composer 3.1. I used CCS 1.2 before. The problem is that I did not success in getting the same .hex file (from the same code) with CCS 1.2 and CCS 3.1 I only have assembly code, no C code. To build my project I only use assember, linker and hex converter). I would like to use CCS 3.1 IDE, with older version of asm500 , and lnk500. It does not work if I just replace the executable in .\C5400\cgtools\bin\ How to do this ? Thank you for your help
[CCS] Build options
Started by ●March 9, 2007
