Hi com.dsp-ers, I know that there are some scenarios in which a line echo canceller should suspend the process of adapting its coefficients: 1. Double talk (the most obvious case) 2. Narrow band reference signal detected 3. Numerical overload detected I wanted to broadcast a call for ideas for detecting scenarios 2 and 3. For 2, I am currently thinking of putting in an 8 channel filter bank and using the relation between a short term estimate of power recorded at the output of the 8 channels to infer narrow band signals and freeze adaptation. For numerical overload, short term estimate of reference signal power is calculated and adaptation frozen in case a defined upper limit is crossed. So, what I would like to ask is: 1. Are there any obvious deficiencies (that I am overlooking) in my approach. 2. Is there a better/standard way of doing either of the two tasks? (I could not find much in the several EC papers I went through, but these were mainly pretty old papers by pioneers of EC). Any help is greatly appreaciated. Regards, Ljubisa Bajic
Line echo cancellation - conditions for freezing adaptation
Started by ●March 10, 2007
Reply by ●March 11, 20072007-03-11
eternal_nan@yahoo.com wrote:> Hi com.dsp-ers, > > I know that there are some scenarios in which a line echo canceller > should suspend the process of adapting its coefficients: > > 1. Double talk (the most obvious case) > 2. Narrow band reference signal detected > 3. Numerical overload detected > > I wanted to broadcast a call for ideas for detecting scenarios 2 and > 3. For 2, I am currently thinking of putting in an 8 channel filter > bank and using the relation between a short term estimate of power > recorded at the output of the 8 channels to infer narrow band signals > and freeze adaptation. For numerical overload, short term estimate of > reference signal power is calculated and adaptation frozen in case a > defined upper limit is crossed. So, what I would like to ask is: > > 1. Are there any obvious deficiencies (that I am overlooking) in my > approach. > 2. Is there a better/standard way of doing either of the two tasks? (I > could not find much in the several EC papers I went through, but these > were mainly pretty old papers by pioneers of EC). > > Any help is greatly appreaciated.There is very little information about anything important in echo cancellation on the internet. There is a lot about the blatantly obvious basics. There is also a lot about achieving the fastest convergence - e.g numerous papers on FAP. That is seldom make or break for a design, though. When it comes to the subtler things, like you are looking at now with narrowband energy, there is very little info. I don't think there is currently a "standard" way to look for narrowband energy in a canceller. An FFT might be one way. What happens if your spectral line signal is rich in harmonics, though? Looking for a peaky autocorrelation function certainly works, though it talks some compute. Low complexity things which directly look for narrowband energy, such as TKEO, might be more direct. Steve
eternal_nan@yahoo.com wrote:> Hi com.dsp-ers, > > I know that there are some scenarios in which a line echo canceller > should suspend the process of adapting its coefficients: > > 1. Double talk (the most obvious case)This is the most important and not so obvious case.> 2. Narrow band reference signal detectedFirst option: you can trigger on the typical narrowband signals like DTMF, dialtone and other signaling tones. Second option: a narrowband signal can be approximately detected by the energy threshold and the average peak to RMS ratio.> 3. Numerical overload detectedThis one is relatively simple, however it depends on the hardware.> > I wanted to broadcast a call for ideas for detecting scenarios 2 and > 3. For 2, I am currently thinking of putting in an 8 channel filter > bank and using the relation between a short term estimate of power > recorded at the output of the 8 channels to infer narrow band signals > and freeze adaptation. For numerical overload, short term estimate of > reference signal power is calculated and adaptation frozen in case a > defined upper limit is crossed. So, what I would like to ask is: > > 1. Are there any obvious deficiencies (that I am overlooking) in my > approach.#2: It may work although it is complex and demands a lot of computation. #3: Not a good idea, since you don't know what is the coupling between the transmit and receive path.> 2. Is there a better/standard way of doing either of the two tasks?Keep it simple. The main advantage of the SG LMS adaptation is its simplicity and low computation requirements.> could not find much in the several EC papers I went through, but these > were mainly pretty old papers by pioneers of EC).I doubt if you can find any advanced information other then the common knowledge from the textbooks. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●March 12, 20072007-03-12
Thanks for the advice guys. On Mar 11, 12:42 am, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote:> eternal_...@yahoo.com wrote: > > Hi com.dsp-ers, > > > I know that there are some scenarios in which a line echo canceller > > should suspend the process of adapting its coefficients: > > > 1. Double talk (the most obvious case) > > This is the most important and not so obvious case. > > > 2. Narrow band reference signal detected > > First option: you can trigger on the typical narrowband signals like > DTMF, dialtone and other signaling tones. > Second option: a narrowband signal can be approximately detected by the > energy threshold and the average peak to RMS ratio. > > > 3. Numerical overload detected > > This one is relatively simple, however it depends on the hardware. > > > > > I wanted to broadcast a call for ideas for detecting scenarios 2 and > > 3. For 2, I am currently thinking of putting in an 8 channel filter > > bank and using the relation between a short term estimate of power > > recorded at the output of the 8 channels to infer narrow band signals > > and freeze adaptation. For numerical overload, short term estimate of > > reference signal power is calculated and adaptation frozen in case a > > defined upper limit is crossed. So, what I would like to ask is: > > > 1. Are there any obvious deficiencies (that I am overlooking) in my > > approach. > > #2: It may work although it is complex and demands a lot of computation. > #3: Not a good idea, since you don't know what is the coupling between > the transmit and receive path. > > > 2. Is there a better/standard way of doing either of the two tasks? > > Keep it simple. The main advantage of the SG LMS adaptation is its > simplicity and low computation requirements. > > > could not find much in the several EC papers I went through, but these > > were mainly pretty old papers by pioneers of EC). > > I doubt if you can find any advanced information other then the common > knowledge from the textbooks. > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.com
