I'm trying to copmute the autocorrelation matrix of array outputs and suspect i may be doing something wrong. I'm confident that i'm getting the right result for vectors but when my signal is a matrix it all goes wrong. Looking at the examples below can anyone say if they are correct? e.g. If X=[1 2 3] autocorrelation matrix = [14 8 3 8 13 6 3 6 9] if X = [ 1 2 3 4 5 6 7 8 9] autocorrelation matrix = [ 285 154 50 154 271 122 50 122 194] Cheers!
Started by ●March 13, 2007
Reply by ●March 13, 20072007-03-13
On 13 Mar, 17:33, "matque" <michelle.mcgu...@eee.strath.ac.uk> wrote:> I'm trying to copmute the autocorrelation matrix of array outputs and > suspect i may be doing something wrong. I'm confident that i'm getting the > right result for vectors but when my signal is a matrix it all goes wrong. > Looking at the examples below can anyone say if they are correct? > > e.g. If X=[1 2 3] > > autocorrelation matrix = [14 8 3 > 8 13 6 > 3 6 9]How did you get that result? It is impossible to answer your question based on numbers alone, you need to tell us how you computed that matrix. Rune
I'm trying to compute: [x(0)x'(0) x(0)x'(1) x(0)x'(2) x(1)x'(0) x(1)x'(1) x(1)x'(2) x(2)x'(0) x(2)x'(1) x(2)x'(2)] where, ' implies a transpose of a conjugate and 0,1 and 2 represent a lag. My understanding of the autocorrelation when dealing with one sequence in time is ok (i think). When I'm dealing with more than one sequence (sensor output) i lose sight of why i'm calculating it the way i am. Perhaps my starting point above is wrong? The code is: %---------------- x= [ 1 2 3;4 5 6;7 8 9] [M,N]=size(x); %N is the number of sensors (rows) and M is the number of samples (columns) for i=1:N X(:,i)=[ x(:,i)' zeros(1,M-1)]; end X=(X(:))'; X1=zeros(M,N*M); for i=1:M for Z=1:N z=Z-1; X1(i,(M*(Z-1)+1:M*Z))=X(:,(i+z*(2*M-1)):(i+M-1+z*(2*M-1))); end end Rxx=X1*conj(X1') %---------------------------
