Does anyone do one of these that will run standalone on a PC? I need one that will fit itself between the output data stream and whatever is creating the audio stream, whether WMP, RealPlayer, WinAmp etc There doesn't appear to be anything that can do this. Is it even possible? I'm even willing to pay a fair amount of money for such a product. -- Dirk http://www.onetribe.me.uk - The UK's only occult talk show Presented by Dirk Bruere and Marc Power on ResonanceFM 104.4 http://www.resonancefm.com
Third Octave Equalizer
Started by ●March 15, 2007
Reply by ●March 16, 20072007-03-16
What about using the free EQ at http://www.kvraudio.com/get/2520.html together with the free VSTHost at http://www.kvraudio.com/get/300.html ?? Uli On 16 Mrz., 02:46, Dirk Bruere at NeoPax <dirk.bru...@gmail.com> wrote:> Does anyone do one of these that will run standalone on a PC? > I need one that will fit itself between the output data stream and > whatever is creating the audio stream, whether WMP, RealPlayer, WinAmp etc > > There doesn't appear to be anything that can do this. > Is it even possible? > I'm even willing to pay a fair amount of money for such a product. > > -- > Dirk > > http://www.onetribe.me.uk- The UK's only occult talk show > Presented by Dirk Bruere and Marc Power on ResonanceFM 104.4http://www.resonancefm.com
Reply by ●March 19, 20072007-03-19
Thanks - I'll check them out. uli.brueggemann@gmail.com wrote:> What about using the free EQ at > http://www.kvraudio.com/get/2520.html > together with the free VSTHost > at > http://www.kvraudio.com/get/300.html ?? > > Uli > > > > On 16 Mrz., 02:46, Dirk Bruere at NeoPax <dirk.bru...@gmail.com> > wrote: >> Does anyone do one of these that will run standalone on a PC? >> I need one that will fit itself between the output data stream and >> whatever is creating the audio stream, whether WMP, RealPlayer, WinAmp etc >> >> There doesn't appear to be anything that can do this. >> Is it even possible? >> I'm even willing to pay a fair amount of money for such a product. >> >> -- >> Dirk >> >> http://www.onetribe.me.uk- The UK's only occult talk show >> Presented by Dirk Bruere and Marc Power on ResonanceFM 104.4http://www.resonancefm.com > >-- Dirk http://www.onetribe.me.uk - The UK's only occult talk show Presented by Dirk Bruere and Marc Power on ResonanceFM 104.4 http://www.resonancefm.com
Reply by ●March 20, 20072007-03-20
>What about using the free EQ at >http://www.kvraudio.com/get/2520.html >together with the free VSTHost >at >http://www.kvraudio.com/get/300.html ?? > >UliHmm... you'll need VAC (Virtual Audio Cable http://software.muzychenko.net/eng/vac.html) or loopback cable (cable from soundcards line-out to line-in) for above software combination to get the EQ working w/ the playback software mentioned there. W/ ASIO capable players you could use ReaRouteASIO driver (comes w/ Cockos Reaper - http://www.cockos.com/reaper/). IIRC, there was one globally working Standalone EQ available but, it was very pricey (~500$) at that time I did searching one. Sorry, but, I can't remember the vendor name anymore. I have not see 1/3 octave EQs for WMP or RealPlayer yet. For WMP there is this IZotope Ozone (http://www.izotope.com/products/audio/media/ozone.html) but I don't know if it has as good EQ features as the original Ozone VST does have. With Winamp, Foobar, J.R MediaCenter and Mediamonkey, as for an example, you can use all those available VST/DX EQ's through VST/DX Host DSP plugins/Bridge plugin. Winamp and MediaMonkey (can be used same plugins): VST support - VST Host DSP for Winamp - http://www.kvraudio.com/forum/viewtopic.php?t=106222&postdays=0&postorder=asc&start=60 DirectX support - FFX-4 for WinAmp - http://perso.wanadoo.fr/vb-audio/us/products/dxrack/dxrack.htm Foobar: Bridge Plug-in for winamp DSP for Foobar 0.8.x-0.9.x or for Foobar 0.9.x - http://pelit.koillismaa.fi/plugins/dsp.php / http://pelit.koillismaa.fi/plugins/plugins/476/foo_dsp_winamp.zip + above mentioned VST Host DSP for Winamp and/or FFX-4 for Winamp. If you like to use several plugins simultaenously, this can be done by loading the Acon EffectChainer (DX/VST) - http://www.acondigital.com/us_EffectChainer.html into VST DSP Host and then those other plugins into it. Here are some more excellent EQ plugins - KarmaFX EQ (VST) - http://karmafx.net/ - Electri-Q posihfopit edition (VST/Winamp)- http://www.aixcoustic.com/index.php/Electri-Q-posihfopit/30/0/ - SSS Linear Phase Graphics EQ (VST) - http://www.geocities.jp/webmaster_of_sss/vst/#lpgeq2 jtp
Dirk Bruere at NeoPax wrote: (snip) http://www.programmersheaven.com/download/3842/Zipfilelist.aspx is a link for Motorola 56001 code for a graphic equalizer. I believe this is the code for one I have somewhere a booklet describing. It reads the values of the potentiometers with an analog multiplexer and A/D converter, then uses those to generate the filter coefficients. My choice would probably be one control for each band, covering both channels, but they did it separately for each channel. This was before the standard for digital audio I/O, so I believe they tapped into a CD player. -- glen -- glen
