Hello all, I am confused about how zero-filling / windowing a signal alters its information content and I'm hoping someone here can help. I have a continuous signal (time domain) and I Fourier transform it to get a band-limited spectrum (frequency domain). From Shannon & Weaver, I can compute the information content of the time domain signal from the signal variance and, given the linearity of a DFT, I expect the information content of the frequency domain signal is the same. The DFT code that I have has the option of zero-filling/zero-padding the original signal as a means of interpolating in the frequency domain. This doesn't change the location/frequency of the peaks in the spectrum but does make it easier to accurately locate the maximum of each peak. So, does zero-filling/zero-padding change the information content of the signal? Many thanks, Dave
Zero padding and the Shannon information content
Started by ●March 16, 2007
Reply by ●March 16, 20072007-03-16
"Dave" <Confused.Scientist@gmail.com> writes:> Hello all, > > I am confused about how zero-filling / windowing a signal alters its > information content and I'm hoping someone here can help. > > I have a continuous signal (time domain) and I Fourier transform it to > get a band-limited spectrum (frequency domain). From Shannon & > Weaver, I can compute the information content of the time domain > signal from the signal variance and, given the linearity of a DFT, I > expect the information content of the frequency domain signal is the > same. > > The DFT code that I have has the option of zero-filling/zero-padding > the original signal as a means of interpolating in the frequency > domain. This doesn't change the location/frequency of the peaks in > the spectrum but does make it easier to accurately locate the maximum > of each peak. So, does zero-filling/zero-padding change the > information content of the signal?Intuitively, no. How to show analytically? Perhaps you could use the Data Processing theorem? -- % Randy Yates % "Maybe one day I'll feel her cold embrace, %% Fuquay-Varina, NC % and kiss her interface, %%% 919-577-9882 % til then, I'll leave her alone." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
> > So, does zero-filling/zero-padding change the > > information content of the signal? > > Intuitively, no. How to show analytically? Perhaps you could use the > Data Processing theorem?Indeed! intuitively, I expect the information content after zero padding to be the same, but I'm at a total loss as to how to prove it. To me, the data processing theorem suggests the opposite as the act of interpolating has altered the signal and hence, destroyed the original information. I suspect that in the early days of information theory someone worked out an analytic proof showing that tapering/ windowing and interpolation does not change the information content of a signal.
On Mar 16, 10:00 am, "Dave" <Confused.Scient...@gmail.com> wrote:> > > So, does zero-filling/zero-padding change the > > > information content of the signal? > > > Intuitively, no. How to show analytically? Perhaps you could use the > > Data Processing theorem? > > Indeed! intuitively, I expect the information content after zero > padding to be the same, but I'm at a total loss as to how to prove > it. To me, the data processing theorem suggests the opposite as the > act of interpolating has altered the signal and hence, destroyed the > original information. I suspect that in the early days of information > theory someone worked out an analytic proof showing that tapering/ > windowing and interpolation does not change the information content of > a signal.I should add that I'm only interested in linear systems and the signal noise is a Gaussian process model. The FFT is a linear transformation of the original signal and by virtue of its inverse (i.e. the IFFT transform) it does not add/destroy information. This suggests that any linear and invertible transformation does not change the information content of a signal. Can anyone recommend a good book on signal processing that considers the information content of the input/output of each process?
Dave wrote:>>> So, does zero-filling/zero-padding change the >>> information content of the signal? >> Intuitively, no. How to show analytically? Perhaps you could use the >> Data Processing theorem? > > Indeed! intuitively, I expect the information content after zero > padding to be the same, but I'm at a total loss as to how to prove > it. To me, the data processing theorem suggests the opposite as the > act of interpolating has altered the signal and hence, destroyed the > original information. I suspect that in the early days of information > theory someone worked out an analytic proof showing that tapering/ > windowing and interpolation does not change the information content of > a signal.How does interpolating destroy original information? Zero padding adds no new information, but if you can tell the added zeros from original data, it removes or subtracts nothing either. What would you consider an analytic proof? Do encrypted and clear versions of the same message carry the same information? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Dave wrote:> On Mar 16, 10:00 am, "Dave" <Confused.Scient...@gmail.com> wrote: >>>> So, does zero-filling/zero-padding change the >>>> information content of the signal? >>> Intuitively, no. How to show analytically? Perhaps you could use the >>> Data Processing theorem? >> Indeed! intuitively, I expect the information content after zero >> padding to be the same, but I'm at a total loss as to how to prove >> it. To me, the data processing theorem suggests the opposite as the >> act of interpolating has altered the signal and hence, destroyed the >> original information. I suspect that in the early days of information >> theory someone worked out an analytic proof showing that tapering/ >> windowing and interpolation does not change the information content of >> a signal. > > I should add that I'm only interested in linear systems and the signal > noise is a Gaussian process model. The FFT is a linear transformation > of the original signal and by virtue of its inverse (i.e. the IFFT > transform) it does not add/destroy information. This suggests that > any linear and invertible transformation does not change the > information content of a signal. > > Can anyone recommend a good book on signal processing that considers > the information content of the input/output of each process?Any entry-level book on signal processing will discuss the properties of direct and inverse Fourier transforms in enough depth to resolve the issues you raise. Like many here, I like Lyons: "Understanding Digital Signal Processing". Smith's "The Scientist and Engineer's Guide to Digital Signal Processing" is on line at http://www.dspguide.com/. There may be material for you in Chapter 8 http://www.dspguide.com/ch8.htm . Zero padding has profound implications processing, aside from the obvious interpolation that makes curves easier to read. DFTs come conceptually from periodic signals, and the math behaves as if it is dealing with complete period(s). Artifacts occur when that's not the case; windowing helps to suppress those at some cost. The inherent periodicity of the math can cause an overlap of the beginning and end data, confusing the result often to the point of uselessness. Zero padding can render the overlap harmless; think of it as a guard band for the real data. The sequence FFT - Multiply by a mask - IFFT achieves convolution, often more quickly than classical convolution. Usually, linear convolution is wanted. Without a sufficient zero-padded guard band, circular convolution results. http://www.dspguide.com/ch7.htm Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
On Mar 16, 1:23 pm, Jerry Avins <j...@ieee.org> wrote:> Dave wrote: > >>> So, does zero-filling/zero-padding change the > >>> information content of the signal? > >> Intuitively, no. How to show analytically? Perhaps you could use the > >> Data Processing theorem? > > > Indeed! intuitively, I expect the information content after zero > > padding to be the same, but I'm at a total loss as to how to prove > > it. To me, the data processing theorem suggests the opposite as the > > act of interpolating has altered the signal and hence, destroyed the > > original information. I suspect that in the early days of information > > theory someone worked out an analytic proof showing that tapering/ > > windowing and interpolation does not change the information content of > > a signal. > > How does interpolating destroy original information? Zero padding adds > no new information, but if you can tell the added zeros from original > data, it removes or subtracts nothing either.Sigh, I should have re-read that before posting it. What I intended to write is that interpolation should not destroy any information but it may (superficially at least) appear to increase it. I was thinking about the data processing theorem which states that the system's output can not contain more information than present in its input. A Fourier transform recasts the input onto a different basis but it doesn't alter the information content. After a little more thought, I think that zero-filling/interpolating/windowing are all methods that result in signal enhancement. In the case of zero-padding, the increase in information content is observed as an improved representation of each spectra line.> What would you consider an analytic proof?Ideally, I'd like to show is that the information content of a signal, H(s), is equal to or less than the information content of a zero- padded signal, H(s'), or a windowed signal, H(s''). In practice, I think it may be easier to show this with a matlab simulation. Thanks, Dave
On Mar 16, 11:26 am, "Dave" <Confused.Scient...@gmail.com> wrote:> On Mar 16, 1:23 pm, Jerry Avins <j...@ieee.org> wrote:......> I was thinking > about the data processing theorem which states that the system's > output can not contain more information than present in its input. A > Fourier transform recasts the input onto a different basis but it > doesn't alter the information content. After a little more thought, I > think that zero-filling/interpolating/windowing are all methods that > result in signal enhancement. In the case of zero-padding, the > increase in information content is observed as an improved > representation of each spectra line. > > DaveA zero-padded (Discrete) Fourier transform casts the input onto a larger set of different bases but it doesn't alter the information content. The new bases are not independent and do not contain any new information. The larger set of bases allows a more accurate estimation of the peak by a peak picking process. The 'improved representation' is only a matter finding a better estimate of a different basis: frequency peaks with amplitudes, than the set that the non-extended DFT provides by peak picking. A variety of interpolation methods allow the same 'improved representation' to be determined. I use quotes around 'improved representation' because it is 'improved' for a specific purpose that is not an information content criteria but a parameter estimation criteria. Dale B. Dalrymple http://dbdimages.com
On Mar 15, 11:06 pm, "Dave" <Confused.Scient...@gmail.com> wrote: [snip]> of each peak. So, does zero-filling/zero-padding change the > information content of the signal? > > Many thanks, > DaveNo. I think you're confusing "information content" and "convenience of representation." It's like when you receive a noisy version of a PAM signal. Quantizing it makes it look nicer and many people then say that it has more information content, but it's the raw data that carries the most information about your transmitted bits. Hope that helps a bit, Julius
On Mar 16, 2:26 pm, "Dave" <Confused.Scient...@gmail.com> wrote:> On Mar 16, 1:23 pm, Jerry Avins <j...@ieee.org> wrote: > > > > > Dave wrote: > > >>> So, does zero-filling/zero-padding change the > > >>> information content of the signal? > > >> Intuitively, no. How to show analytically? Perhaps you could use the > > >> Data Processing theorem? > > > > Indeed! intuitively, I expect the information content after zero > > > padding to be the same, but I'm at a total loss as to how to prove > > > it. To me, the data processing theorem suggests the opposite as the > > > act of interpolating has altered the signal and hence, destroyed the > > > original information. I suspect that in the early days of information > > > theory someone worked out an analytic proof showing that tapering/ > > > windowing and interpolation does not change the information content of > > > a signal. > > > How does interpolating destroy original information? Zero padding adds > > no new information, but if you can tell the added zeros from original > > data, it removes or subtracts nothing either. > > Sigh, I should have re-read that before posting it. What I intended > to write is that interpolation should not destroy any information but > it may (superficially at least) appear to increase it. I was thinking > about the data processing theorem which states that the system's > output can not contain more information than present in its input. A > Fourier transform recasts the input onto a different basis but it > doesn't alter the information content. After a little more thought, I > think that zero-filling/interpolating/windowing are all methods that > result in signal enhancement. In the case of zero-padding, the > increase in information content is observed as an improved > representation of each spectra line. > > > What would you consider an analytic proof? > > Ideally, I'd like to show is that the information content of a signal, > H(s), is equal to or less than the information content of a zero- > padded signal, H(s'), or a windowed signal, H(s''). In practice, I > think it may be easier to show this with a matlab simulation. > > Thanks, > DaveYour intuition seems to be at odds with what you said previously. You had (correctly, I believe) pointed out that since the FFT has an inverse that can be used to exactly reconstruct the FFT's input, the FFT operation doesn't add or destroy any information content. The same can be said about zero-padding or bandlimited interpolation. Both have exact inverse operations that yield the original signal, so they can't possibly change the information content. Jason
