Difference between maximum ratio combing and adaptive beamforming
Started by dgse ●March 22, 2007
Q1:In receiver side, what is difference between maximum ratio combing
and adaptive beamforming?
Q2: In transmitter side, what is difference between maximum ratio
combing and adaptive beamforming?
On 23 Mar, 03:09, "dgse" <dgsei...@gmail.com> wrote:
> Q1:In receiver side, what is difference between maximum ratio combing > and adaptive beamforming? > Q2: In transmitter side, what is difference between maximum ratio > combing and adaptive beamforming?
Homework? Rune
No!
On Mar 23, 12:16 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote:
> On 23 Mar, 03:09, "dgse" <dgsei...@gmail.com> wrote: > > > Q1:In receiver side, what is difference between maximum ratio combing > > and adaptive beamforming? > > Q2: In transmitter side, what is difference between maximum ratio > > combing and adaptive beamforming? > > Homework? > > Rune
Realize that your question is not well-formed. There are many flavors of "adaptive beamforming", which one are you talking about? Julius
"dgse" <dgseigig@gmail.com> wrote in message
news:1174630280.129018.82510@l77g2000hsb.googlegroups.com...
> On Mar 23, 12:16 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote: >> On 23 Mar, 03:09, "dgse" <dgsei...@gmail.com> wrote: >> >> > Q1:In receiver side, what is difference between maximum ratio combing >> > and adaptive beamforming? >> > Q2: In transmitter side, what is difference between maximum ratio >> > combing and adaptive beamforming? >> >> Homework? >> > No! >
I have never heard of maximum ratio combing. Do you have a reference? Best of luck - Mike
On Mar 23, 9:58 am, "Mike Yarwood" <mpyarw...@btopenworld.com> wrote:
> "dgse" <dgsei...@gmail.com> wrote in message > > news:1174630280.129018.82510@l77g2000hsb.googlegroups.com...> On Mar 23, 12:16 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote: > >> On 23 Mar, 03:09, "dgse" <dgsei...@gmail.com> wrote: > > >> > Q1:In receiver side, what is difference between maximum ratio combing > >> > and adaptive beamforming? > >> > Q2: In transmitter side, what is difference between maximum ratio > >> > combing and adaptive beamforming? > > >> Homework? > > > No! > > I have never heard of maximum ratio combing. Do you have a reference? > > Best of luck - Mike
A nice ap note from a quick Google: http://www.freescale.com/files/dsp/doc/app_note/AN2251.pdf This begins with examples of MRC concepts in the System Model section. An example: http://www.iss.rwth-aachen.de/4_publikationen/res_pdf/Schmitt_ISSSTA_2004.pdf And a definition: http://encyclopedia.thefreedictionary.com/Maximum+ratio+combining MRC seems to be about combining schemes for 'channels'. 'Channels' might be, but need not be beams. MRC is an operation adapting on signal quality to optimize BER, not form a spatial response pattern. So. the answer to Q1 and Q2 is that beamformers form beams and MRC doesn't care whether channels are beams, which is why the original question seems ill-formed. A more useful response might be that there could be scenarios where the MRC process produces a beamformer, but the MRC algorithm might not know or care. Dale B. Dalrymple http://dbdimages.com
On Mar 24, 11:54 am, "dbd" <d...@ieee.org> wrote:
> On Mar 23, 9:58 am, "Mike Yarwood" <mpyarw...@btopenworld.com> wrote: > > > > > "dgse" <dgsei...@gmail.com> wrote in message > > >news:1174630280.129018.82510@l77g2000hsb.googlegroups.com...> On Mar 23, 12:16 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote: > > >> On 23 Mar, 03:09, "dgse" <dgsei...@gmail.com> wrote: > > > >> > Q1:In receiver side, what is difference between maximum ratio combing > > >> > and adaptive beamforming? > > >> > Q2: In transmitter side, what is difference between maximum ratio > > >> > combing and adaptive beamforming? > > > >> Homework? > > > > No! > > > I have never heard of maximum ratio combing. Do you have a reference? > > > Best of luck - Mike > > A nice ap note from a quick Google:http://www.freescale.com/files/dsp/doc/app_note/AN2251.pdf > This begins with examples of MRC concepts in the System Model section. > > An example:http://www.iss.rwth-aachen.de/4_publikationen/res_pdf/Schmitt_ISSSTA_... > > And a definition:http://encyclopedia.thefreedictionary.com/Maximum+ratio+combining > > MRC seems to be about combining schemes for 'channels'. 'Channels' > might be, but need not be beams. MRC is an operation adapting on > signal quality to optimize BER, not form a spatial response pattern. > So. the answer to Q1 and Q2 is that beamformers form beams and MRC > doesn't care whether channels are beams, which is why the original > question seems ill-formed. > > A more useful response might be that there could be scenarios where > the MRC process produces a beamformer, but the MRC algorithm might not > know or care. > > Dale B. Dalrymplehttp://dbdimages.com
Thanks dbd Basically, what I am understand is for MRC the weight is real number and for beamforming the weight is complex number.
Let me try to rephrase the question.
In traditional beam-forming, we are always talking about angles, angle of
arrival, angle of departure, beam pattern pointing to a certain angle,
etc.
However, when we talk about the MRC, the concept of angle disappears and
what we cared is only maximizing the SNR (or some other related metric).
Why we do not see/talk about the angles any more in MRC? I try to answer
this question. Please share your comments and criticism.
In traditional beamforming, we often are in a line-of-sight scenario,
e.g., in application of satellite, radar, etc. Remember we always talk
about a incident plane wave in the beamforming textbook? In such cases,
the channel is more like a Rician channel in mobile communication
terminology. If we carry out MRC in such a scenario, the solution will be
the same as what traditional beamforming will give us. And in such cases,
given the simple LOS channel, the beamforming vector does reflect the
actual geometry via the angle of arrival/departure. That's why we can talk
about angles in traditional beamforming.
In MRC, we often are in a non-line-of-sight scenario with fading not
negligible. There are probably multi-path involved, with more than paths
arriving in different directions. The channel is more like Rayleigh
(Rician channel with small Rician factor K) channel in mobile
communication terminology. MRC is still the optimal solution. However,
given that multiple paths arriving from different directions, we can not
follow up on the geometry any more. And that's why we no longer talk about
angles any more in general MRC.
On the other hand, I think we can still plot beam patterns in MRC case.
The problem is that, the beam pattern may not reflect the actual geometry
very well. By actual geometry, I mean actual position/direction of where
the transmitter/receiver is.
I am not sure whether this is true or not. Please let me know your
comments.
>On Mar 23, 9:58 am, "Mike Yarwood" <mpyarw...@btopenworld.com> wrote: >> "dgse" <dgsei...@gmail.com> wrote in message >> >> news:1174630280.129018.82510@l77g2000hsb.googlegroups.com...> On Mar
>> >> On 23 Mar, 03:09, "dgse" <dgsei...@gmail.com> wrote: >> >> >> > Q1:In receiver side, what is difference between maximum ratio
combing
>> >> > and adaptive beamforming? >> >> > Q2: In transmitter side, what is difference between maximum ratio >> >> > combing and adaptive beamforming? >> >> >> Homework? >> >> > No! >> >> I have never heard of maximum ratio combing. Do you have a reference? >> >> Best of luck - Mike > >A nice ap note from a quick Google: >http://www.freescale.com/files/dsp/doc/app_note/AN2251.pdf >This begins with examples of MRC concepts in the System Model section. > >An example: >http://www.iss.rwth-aachen.de/4_publikationen/res_pdf/Schmitt_ISSSTA_2004.pdf > >And a definition: >http://encyclopedia.thefreedictionary.com/Maximum+ratio+combining > >MRC seems to be about combining schemes for 'channels'. 'Channels' >might be, but need not be beams. MRC is an operation adapting on >signal quality to optimize BER, not form a spatial response pattern. >So. the answer to Q1 and Q2 is that beamformers form beams and MRC >doesn't care whether channels are beams, which is why the original >question seems ill-formed. > >A more useful response might be that there could be scenarios where >the MRC process produces a beamformer, but the MRC algorithm might not >know or care. > >Dale B. Dalrymple >http://dbdimages.com > >
_____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
Phil,
It just so happens that I'm taking Information Theory this semester and we
just covered capacity of a MIMO system in fading channels. Your explanation
closely matches the professor's. He wouldn't call it "beamforming gain" for
the same reasons you stated.
--Randy
"philgo" <philgo@gmail.com> writes:
> Let me try to rephrase the question. > > In traditional beam-forming, we are always talking about angles, angle of > arrival, angle of departure, beam pattern pointing to a certain angle, > etc. > However, when we talk about the MRC, the concept of angle disappears and > what we cared is only maximizing the SNR (or some other related metric). > > Why we do not see/talk about the angles any more in MRC? I try to answer > this question. Please share your comments and criticism. > > In traditional beamforming, we often are in a line-of-sight scenario, > e.g., in application of satellite, radar, etc. Remember we always talk > about a incident plane wave in the beamforming textbook? In such cases, > the channel is more like a Rician channel in mobile communication > terminology. If we carry out MRC in such a scenario, the solution will be > the same as what traditional beamforming will give us. And in such cases, > given the simple LOS channel, the beamforming vector does reflect the > actual geometry via the angle of arrival/departure. That's why we can talk > about angles in traditional beamforming. > > In MRC, we often are in a non-line-of-sight scenario with fading not > negligible. There are probably multi-path involved, with more than paths > arriving in different directions. The channel is more like Rayleigh > (Rician channel with small Rician factor K) channel in mobile > communication terminology. MRC is still the optimal solution. However, > given that multiple paths arriving from different directions, we can not > follow up on the geometry any more. And that's why we no longer talk about > angles any more in general MRC. > > On the other hand, I think we can still plot beam patterns in MRC case. > The problem is that, the beam pattern may not reflect the actual geometry > very well. By actual geometry, I mean actual position/direction of where > the transmitter/receiver is. > > I am not sure whether this is true or not. Please let me know your > comments. > >>On Mar 23, 9:58 am, "Mike Yarwood" <mpyarw...@btopenworld.com> wrote: >>> "dgse" <dgsei...@gmail.com> wrote in message >>> >>> news:1174630280.129018.82510@l77g2000hsb.googlegroups.com...> On Mar > 23, 12:16 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote: >>> >> On 23 Mar, 03:09, "dgse" <dgsei...@gmail.com> wrote: >>> >>> >> > Q1:In receiver side, what is difference between maximum ratio > combing >>> >> > and adaptive beamforming? >>> >> > Q2: In transmitter side, what is difference between maximum ratio >>> >> > combing and adaptive beamforming? >>> >>> >> Homework? >>> >>> > No! >>> >>> I have never heard of maximum ratio combing. Do you have a reference? >>> >>> Best of luck - Mike >> >>A nice ap note from a quick Google: >>http://www.freescale.com/files/dsp/doc/app_note/AN2251.pdf >>This begins with examples of MRC concepts in the System Model section. >> >>An example: >>http://www.iss.rwth-aachen.de/4_publikationen/res_pdf/Schmitt_ISSSTA_2004.pdf >> >>And a definition: >>http://encyclopedia.thefreedictionary.com/Maximum+ratio+combining >> >>MRC seems to be about combining schemes for 'channels'. 'Channels' >>might be, but need not be beams. MRC is an operation adapting on >>signal quality to optimize BER, not form a spatial response pattern. >>So. the answer to Q1 and Q2 is that beamformers form beams and MRC >>doesn't care whether channels are beams, which is why the original >>question seems ill-formed. >> >>A more useful response might be that there could be scenarios where >>the MRC process produces a beamformer, but the MRC algorithm might not >>know or care. >> >>Dale B. Dalrymple >>http://dbdimages.com >> >> > > > > > > _____________________________________ > Do you know a company who employs DSP engineers? > Is it already listed at http://dsprelated.com/employers.php ?
-- % Randy Yates % "Though you ride on the wheels of tomorrow, %% Fuquay-Varina, NC % you still wander the fields of your %%% 919-577-9882 % sorrow." %%%% <yates@ieee.org> % '21st Century Man', *Time*, ELO http://home.earthlink.net/~yatescr
philgo said the following on 20/04/2007 19:23:
A very close analogy is that of Wiener deconvolution (http://en.wikipedia.org/wiki/Wiener_deconvolution), where we're trying to invert an LTI system h(t). Naively, we might think to do this in the frequency domain simply by multiplying by 1/H(f) (where H(f) <=> h(t)). However, the optimal solution from an SNR point of view is the Wiener deconvolution. Similarly, in antenna arrays, the optimal SNR solution is MRC (which is also a Wiener solution), not "naive" beamforming. However, in both situations, when the noise is removed, the Wiener/MRC solution reduces to the "naive" solution. -- Oli
