I start CCS v.3 from CCS Setup after configure devices using default configure. I get a error message : Error initializing emulator Board Name: OMAP1510 ES2 XDS560 Emulator Cpu Name: ARM9_0 Abort: Close Code Composer Studio. Retry: Try to initialize the emulator again. Ignore: Ignore the initialization error and start potentially without target debugging access. Diagnostic: Run diagnostic utility. Help me know how fix this error. Thanks Regards
Problem with CCS v3.3
Started by ●March 24, 2007
Reply by ●March 26, 20072007-03-26
Hello sdses, There's a tool called XDSPROBE, search for it in CCS files. There may be also an out-file for your emulator (You haven't mentioned which one you use). Then you can try basic commands like: XDSPROBE -F yourFile.out -r -o ..\log\wolfgang.log or XDSPROBE -F yourFile.out -g -o ..\log\wolfgang.log First on resets you emulator, second tests the scan path. Regards, Wolfgang
