Dear All, I am trying to get images from the google image search engine to my hard-disk. I managed to query the google through the following in matlab. web(['http://images.google.com/images?q= mario ] What I need is to find a way /code in Matlab to download the images found to a directory on my harddisk for further processing. Is there anyone there that can help me out? I need it for my project. I thank you in advance, Mario
how to retrieve image from google
Started by ●March 26, 2007
Reply by ●March 26, 20072007-03-26
mariociliaattard@gmail.com wrote:> Dear All, > > I am trying to get images from the google image search engine to my > hard-disk. I managed to query the google through the following in > matlab. > web(['http://images.google.com/images?q= mario ] > > > What I need is to find a way /code in Matlab to download the images > found to a directory on my harddisk for further processing. Is there > anyone there that can help me out? I need it for my project.This is not the best group for that question. Right click on the image. Select "Save image as". Decide where to put it. As to Matlab, I can't say. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
with query,, try to write into some folder IMWRITE() and later use DIR..function which gives the output in form of structure and then using a comparison for .jpg or .jpeg or .bmp or any..image extension to do offline processing.. try around..above should help you particle (filter) reddy On Mar 26, 1:00 pm, "mariociliaatt...@gmail.com" <mariociliaatt...@gmail.com> wrote:> Dear All, > > I am trying to get images from the google image search engine to my > hard-disk. I managed to query the google through the following in > matlab. > web(['http://images.google.com/images?q=mario ] > > What I need is to find a way /code in Matlab to download the images > found to a directory on my harddisk for further processing. Is there > anyone there that can help me out? I need it for my project. > > I thank you in advance, > Mario
Reply by ●March 28, 20072007-03-28
mariociliaattard@gmail.com wrote:> I am trying to get images from the google image search engine to my > hard-disk. I managed to query the google through the following in > matlab. > web(['http://images.google.com/images?q= mario ]Look for the wget program, available from the GNU people. wget http://images.google.com/images?q=mario will write it to your hard disk. I believe you can specify the file name if you don't like the one it chooses. You should be able to run it from inside matlab. -- glen
