Hi; I'm having a little trouble implementing the all-pass filter. I have implemented an all-pass filter, when I run it on the DSK it seems work fine; the output sound of the filter is the same as the input (but just a little quieter). However, if I increase R (delay value) to more than 192 samples (=4ms with sample rate of 48khz), i get a really high pitch ringing effect! Also, when the output of the allpass filter is mixed with the original input, there is no phasing effect audible what so ever! I have listed my filter code which I have designed using the description written here: http://www.harmony-central.com/Effects/Articles/Phase_Shifting/ Here's the allpass filter function: /*************************************************************************/ /** **/ /** FUNCTION : allPassFilter **/ /** DESCRIPTION : Function to apply an allpass filter to the input **/ /** audio data. **/ /** REQUIRES : addresss of current input L & R audio samples **/ /** the number of samples used by the delay [R] **/ /** **/ /*************************************************************************/ void allPassFilter(short int * left, short int * right, int sampleDelay){ float l_forward; /* feedforward value for left channel */ float r_forward; /* feedforward value for right channel */ static float l_back; /* feedback value for left channel */ static float r_back; /* feedback value for right channel */ static short int readPtr=0; /* stores position in buffer to read data */ static short int writePtr=0;/* stores position in buffer to write data */ static int alpha = 0.8; /* alpha value used for feedforward & back */ /* calculate the feedforward values */ l_forward = alpha * *left; r_forward = alpha * *right; /* Calculate position of the read & write pointers */ if (writePtr < sampleDelay ) readPtr = (((SAMPLE_RATE/1000)*MAX_DELAY) - (sampleDelay - writePtr)); else readPtr = writePtr - sampleDelay; if (++writePtr >= MAX_DELAY) writePtr = 0; /* now add current audio sample to array */ lBuffer[writePtr] = calculateAverage(*left, (short int)l_back); rBuffer[writePtr] = calculateAverage(*right, (short int)r_back); /* calculate output values */ *left = calculateAverage(lBuffer[readPtr], (short int)l_forward); *right = calculateAverage(rBuffer[readPtr], (short int)r_forward); /* calculate the feedback values */ l_back = (0-alpha) * *left; r_back = (0-alpha) * *right; } And in my main method, here is the call to the filter inputL = input value from mcbsp intputR = input value from mcbsp outL = inputL; /* to allow filter to edit the outL value using ptrs */ outR = outL; /* to allow filter to edit the outR value using ptrs */ /* apply the allpassfilter - R=192 */ allPassFilter(&outL, &outR, 192); /* mixEffect: dry, wet, dry value, wet value */ mcbsp1_write(mixEffect(inputL, outL, 0.5, 0.6)); mcbsp1_write(mixEffect(inputR, outR, 0.5, 0.6)); /* write the current audio level to the audio meter */ audioMeter(calculateAverage(inputL, inputR)); Can anybody tell me where the constant high-pitch sound comes from when the delay goes above approx 4ms??? And whether this is a correct implementation of a 1st stage all pass filter, and if not, where to point me to put me on the right lines! Thanks... _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
All Pass Filter design
Started by ●March 28, 2007
Reply by ●March 28, 20072007-03-28
Do I have to implement an LFO to control the delay time so it varies? I thought that the Phaser did not require an LFO? Is this why there is no audible phase shifting? _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
