Currently being voted on by the IEEE, an extension to the IEEE 754 floating-point standard will include the definition of a decimal floating-point format. This has some interesting features. Decimal digits are usually compressed using the Densely Packed Decimal format developed by Mike Cowlishaw at IBM on the basis of the earlier Chen-Ho encoding. The three formats offered all have a number of decimal digits precision that is 3n+1 for some n, so a five-bit field combines the one odd digit with the most significant portion of the exponent (for a range of exponents that has 3*2^n values for some integer n) to keep the coding efficient. Its most unusual, and potentially controversial, feature is the use it makes of unnormalized values. One possible objection to a decimal floating-point format, if it were used in general for all the purposes for which floating-point is used, is that the precision of numbers in such a format can vary by a whole decimal digit, which is more than three times as large as a binary bit, the amount by which the precision varies in a binary format with a radix-2 exponent. (There were binary formats with radix-16 exponents, on the IBM System/360 and the Telefunken TR 440, and these were found objectionable, although the radix-8 exponents of the Atlas and the Burroughs B5500 were found tolerable.) I devised a scheme, described along with the proposed new formats, on http://www.quadibloc.com/comp/cp020302.htm by which a special four-bit field would describe both the most significant digit of a decimal significand (or coefficient, or fraction, or, horrors, mantissa) and a least significant digit which would be restricted in the values which it could take. MSD 1, appended LSD can be 0, 2, 4, 6, or 8. MSD 2 or 3, appended LSD can be 0 or 5. MSD 4 to 9, appended LSD is always 0. In this way, the distance between representable values increases in steps of factors of 2 or 2.5 instead of factors of 10, making decimal floating-point as "nice" as binary floating-point. As another bonus, when you compare the precision of the field to its length in bits, you discover that I have managed to achieve the same benefit for decimal floating point as was obtained for binary floating- point by hiding the first bit of a normalized significand! Well, I went on from there. If one can, by this contrivance, make the exponent move in steps of 1/3rd of a digit instead of whole digits, why not try to make the exponent move in steps of about 1/3 of a bit, or 1/10 of a digit? And so, on the next page, http://www.quadibloc.com/comp/cp020303.htm I note that if instead of appending one digit restricted to being either even or a multiple of five, I append values in a *six-digit* field, I can let the distance between representable points increase by gentle factors of 1.25 or 1.28. But such a format is rather complicated. I go on to discuss using an even smaller factor with sexagesimal floating point... in a format more suited to an announcement *tomorrow*. But I also mention how this scheme could be _simplified_ to a minimum. Let's consider normalized binary floating points. The first two bits of the significand (or mantissa) might be 10 or 11. In the former case, let's append a fraction to the end of the significand that might be 0, 1/3 or 2/3... except, so that we can stay in binary, we'll go with either 5/16 or 11/16. In the latter case, the choice is 0 or 1/2. Then, the coding scheme effectively makes the precision of the number move in small jumps, as if the exponent were in units of *half* a bit instead of whole bits. But now a nagging feeling haunts me. This sounds vaguely familiar - as if, instead of *inventing* this scheme, bizarre though it may sound to many, I just *remembered* it, say from the pages of an old issue of Electronics or Electronics Design magazine. Does anyone here remember what I'm thinking of? John Savard
Unusual Floating-Point Format Remembered?
Started by ●March 31, 2007
Reply by ●March 31, 20072007-03-31
"Quadibloc" <jsavard@ecn.ab.ca> wrote:> Currently being voted on by the IEEE, an extension to the IEEE 754 > floating-point standard will include the definition of a decimal > floating-point format. > > This has some interesting features ... Its most unusual, and potentially > controversial, feature is the use it makes of unnormalized values.Not at all sure why you keep writing this, John -- that's the way amost all existing decimal floating-point arithmetic works, and has done for several hundred years. It was, perhaps, controversial around 1202 in Europe (e.g., Liber Abaci, by Fibonacci) -- but since 1500 or so, that's the way arithmetic has been done, even in the late-adopting countries of Europe. :-) mfc
Mike Cowlishaw wrote:> It was, perhaps, controversial around > 1202 in Europe (e.g., Liber Abaci, by Fibonacci) -- but since 1500 or > so, that's the way arithmetic has been done, even in the late-adopting > countries of Europe. :-)LOL! People designing floating-point units for computers, however, have somewhat different tastes from those using pencil and paper. As a result, while they never even considered using Roman numerals for that purpose, other aspects of how decimal arithmetic is done by hand have tended, as a general practice, to be modified in the floating-point units of computers. John Savard
In article <1175358668.762078.281610@n59g2000hsh.googlegroups.com>, "Quadibloc" <jsavard@ecn.ab.ca> writes: |> |> One possible objection to a decimal floating-point format, if it were |> used in general for all the purposes for which floating-point is used, |> is that the precision of numbers in such a format can vary by a whole |> decimal digit, which is more than three times as large as a binary |> bit, the amount by which the precision varies in a binary format with |> a radix-2 exponent. (There were binary formats with radix-16 |> exponents, on the IBM System/360 and the Telefunken TR 440, and these |> were found objectionable, although the radix-8 exponents of the Atlas |> and the Burroughs B5500 were found tolerable.) As I pointed out, this is at most a storm in a teacup. The reason that those formats were found objectionable was the truncation, and had nothing to do with the base. There is no critical reason not to use a base of 10 as against a base of 2. And I speak as someone with practical experience of writing and porting base-independent numerical code. My arguments with Mike have nothing to do with saying that decimal is harmful IN ITSELF. They are that the way IEEE 754R decimal is being spun is misleading and often incorrect, and the consequences of this are harmful, verging on the catastrophic. Regards, Nick Maclaren.
> My arguments with Mike have nothing to do with saying that decimal > is harmful IN ITSELF. They are that the way IEEE 754R decimal is > being spun is misleading and often incorrect, and the consequences > of this are harmful, verging on the catastrophic.As far as I know, 'IEEE 754r decimal' is not being "spun", at all -- in fact people opposed to it seem to be far more noisy about it than those who are quietly using it.
Nick Maclaren wrote:> As I pointed out, this is at most a storm in a teacup. The reason that > those formats were found objectionable was the truncation, and had > nothing to do with the base.In most cases, the truncation is a _consequence_ of the base. I *have* come up with a way in which one could have a base-10 format whose truncation is (almost) as gentle as that of a binary floating- point format, though, so I know that an exception is possible. I do not know if any controversy has, in fact, raged around the proposed DFP format, but I suspect that if there are people who find the format off-putting, most of them will be exercised not by subtle differences in numerical properties, but instead, when they notice the free use of unnormalized values - and then see the "ideal exponent" rules - they will realize that this isn't their grandfather's floating- point, and that something rather novel is being done here. Some, seeing this bold and novel idea, will stand up and applaud. Using the z9 implementation as an example, they will not feel threatened by it - if the new format runs much slower than binary floating-point, clearly, it isn't intended as a replacement, and so if it has poorer numeric properties for classic floating-point applications, that isn't really an issue. It's there to take computers into new applications. But others will see this as just the beginning - and, certainly, if the transistors are worth it, hardware implementations of DFP having near-parity in speed with binary floating-point are possible. If DFP can do everything BFP can do, and then some, why not? And if that is an eventual possibility, DFP ought to be put under intense scrutiny right now, before it's too late! Well, if there _is_ controversy, my humble contribution might just save DFP. Because what I worked out is a DFP that looks "just like" binary floating point. The storage efficiency is the same as BFP - I managed to simulate hiding the first bit! The truncation changes by small steps nearly as small as those of BFP - good enough to answer your specific example, for which the threshold is radix-4. The same hardware could handle both my trivial modification of the DFP proposal *and* the one proposed as the standard. So there would simply be a choice between format-centric DFP and numeric-centric DFP, and it would be safe to drop binary floating point, because numeric-centric DFP would preserve those of its good points perhaps not fully reflected in the current DFP proposal. John Savard
Reply by ●April 1, 20072007-04-01
In article <eumamv$a21$1$8300dec7@news.demon.co.uk>,
"Mike Cowlishaw" <mfc@uk.ibm.com> writes:
|> quietly using it.
I have tried to give you credit for being honest and fair, but it is
getting increasingly hard. Your Web pages spin and postings spin the
advantages of decimal, and so do a hell of a lot of things taken from
them - the Python Decimal class documentation, for example.
All I have ever done is to point out the misleading claims, both ones
of fact and ones of presentation, and the inconsistencies; and to point
out that, in the opinion of all the people with extensive numerical and
pedagogical experience that I know of, the value judgements used to
justify decimal are mistaken.
To point out one egregious inconsistency, you have claimed that the
use of 128-bit decimal for fixed-point calculations will be universal,
that the cost of implementing decimal is only a little more than that
of binary and that decimal is intended to replace binary. I can't
recall whether you (or others) have also said that decimal is NOT
intended to replace binary, but be in addition, in order to say that
my points are irrelevant - but it has been said by its proponents!
Those CANNOT all be true at once.
1) The cost of implementing decimal is slightly more than the
cost of implementing binary only in the case of the VERY heavyweight
floating-point units produced by IBM. I don't know its cost in the
other ones, but would expect it to be at least twice as much in the
stripped-down ones favoured for embedded work. And that is not just
development and sales cost, but power consumption for a given
performance.
2) Where floating-point is a major factor, the use of 128-bit
arithmetic doubles the cost for a given performance (or conversely),
as the current bottleneck is memory access. Twice as much memory
with twice the bandwidth costs twice as much and needs twice the
power. You simply can't get round that.
3) If you don't use 128-bit arithmetic, there WILL be overflow
problems with fixed-point. You can't enable trapping, because the
exception that needs to be trapped MUST be ignored when you are using
the arithmetic for floating-point. I won't go into the errors made
by the IEEE 754(R) people about why language support is effectively
absent, but that isn't going to change.
Regards,
Nick Maclaren.
In article <eunnnh$d26$1@gemini.csx.cam.ac.uk>, nmm1@cus.cam.ac.uk (Nick Maclaren) writes: |> |> All I have ever done is to point out the misleading claims, both ones |> of fact and ones of presentation, and the inconsistencies; and to point |> out that, in the opinion of all the people with extensive numerical and |> pedagogical experience that I know of, the value judgements used to |> justify decimal are mistaken. Correction. Except for Professor Kahan. I will repeat, ad tedium, that the universal opinion is that there is essentially no difference between binary and decimal floating-point for numerical work. The former is marginally better for 'serious' work, on many grounds, and the latter marginally more convenient for 'trivial' work. Regards, Nick Maclaren.
> I have tried to give you credit for being honest and fair, but it is > getting increasingly hard. Your Web pages spin and postings spin the > advantages of decimal, and so do a hell of a lot of things taken from > them - the Python Decimal class documentation, for example.I think you must be using the word 'spin' in a different way than I do :-). I point out facts, but that's not 'spin'. And I don't think I refer to the 'advantages' of decimal arithmetic anywhere...> To point out one egregious inconsistency, you have claimed that the > use of 128-bit decimal for fixed-point calculations will be universal, > that the cost of implementing decimal is only a little more than that > of binary and that decimal is intended to replace binary.I actually expected the 64-bit format to be the more popular. It was a surprise to me that people are standardizing on the 128-bit format. On the costs, the components needed are about 15%-20% more than binary, according to most references. That is actually quite significant when multiplied over a large number of cores. I have never said that decimal is intended to replace binary. If your data are in binary, why convert to decimal?> I can't > recall whether you (or others) have also said that decimal is NOT > intended to replace binary, but be in addition, in order to say that > my points are irrelevant - but it has been said by its proponents! > > Those CANNOT all be true at once. > > 1) The cost of implementing decimal is slightly more than the > cost of implementing binary only in the case of the VERY heavyweight > floating-point units produced by IBM. I don't know its cost in the > other ones, but would expect it to be at least twice as much in the > stripped-down ones favoured for embedded work. And that is not just > development and sales cost, but power consumption for a given > performance.I cannot imagine how it could be twice; a decimal adder, for example, is only slightly more costly than a binary one (it has to carry at 9 rather than 15). Multipliers are more complex, to be sure (but lots of people are doing new research on that). On the other hand, zeros and subnormal numbers are somewhat easier to handle in the 754r decimal formats because they are unnormalized and so zeros and subnormals are not a special case. And, of course, an all-decimal computer wouldn't need a binary integer unit :-).> 2) Where floating-point is a major factor, the use of 128-bit > arithmetic doubles the cost for a given performance (or conversely), > as the current bottleneck is memory access. Twice as much memory > with twice the bandwidth costs twice as much and needs twice the > power. You simply can't get round that.Of course. The same is true of 128-bit ('quad') binary arithmetic, too. I rather assume most binary FP processing will migrate to that size, too, just as it migrated from single to double when the latter became widely available.> 3) If you don't use 128-bit arithmetic, there WILL be overflow > problems with fixed-point. You can't enable trapping, because the > exception that needs to be trapped MUST be ignored when you are using > the arithmetic for floating-point. I won't go into the errors made > by the IEEE 754(R) people about why language support is effectively > absent, but that isn't going to change.We are somewhat agreed on that :-). However, one can detect possible rounding even at the smaller sizes (with the effective loss of a digit of precision) by checking the MSD (which is conveniently in the top byte of the encoding). If it is still zero after a multiplication, for example, there was no rounding (except possibly for subnormal results, but when doing fixed-point arithmetic one is unliklely to be anywhere near the extremes of exponent range). mfc
In article <euo407$qia$1$8302bc10@news.demon.co.uk>, "Mike Cowlishaw" <mfc@uk.ibm.com> writes: |> > I have tried to give you credit for being honest and fair, but it is |> > getting increasingly hard. Your Web pages spin and postings spin the |> > advantages of decimal, and so do a hell of a lot of things taken from |> > them - the Python Decimal class documentation, for example. |> |> I think you must be using the word 'spin' in a different way than I do :-). |> I point out facts, but that's not 'spin'. And I don't think I refer to the |> 'advantages' of decimal arithmetic anywhere... You do, frequently, which is is reasonable. What you don't do is give fair weight to the disadvantages and, more importantly, phrase your claims in ways in which the naive will assume that the advantages are more than they are. |> I have never said that decimal is intended to replace binary. If your data |> are in binary, why convert to decimal? http://groups.google.com/group/comp.arch.arithmetic/browse_thread/ thread/1c9d39e3aa57952d/fb34632082279900?lnk=st&q=&rnum=2&hl=en#fb34632082279900 Mike Cowlishaw wrote: ...> Integers (and integer arithmetic) are a proper subset of the > decimal numbers and arithmetic. There's really no need for > the binary integers at the application level. They'll be there > for a while, to be sure, but things will be so much simpler > 20-30 years from now when we are back to all-decimal > machines again :-)).Yes, there was a smiley. But I remember similar remarks without them, perhaps in Email. And IEEE 754R makes decimal an ALTERNATIVE to binary, despite the claims that it is supposed to be an addition. |> I cannot imagine how it could be twice; a decimal adder, for example, is |> only slightly more costly than a binary one (it has to carry at 9 rather |> than 15). Multipliers are more complex, to be sure (but lots of people are |> doing new research on that). On the other hand, zeros and subnormal numbers |> are somewhat easier to handle in the 754r decimal formats because they are |> unnormalized and so zeros and subnormals are not a special case. And, of |> course, an all-decimal computer wouldn't need a binary integer unit :-). You can use the same multiplier and divider as integers, and those units are MUCH larger than the adder; conversion to and from integers is vastly easier, and so on. The IEEE 754R format also forces the support of unnormalised numbers, which adds extra complexity even for comparison. For reasons that you know perfectly well, there isn't the chance of a flea in a furnace of integers becoming decimal during either of our working lifetimes, or a couple of decades beyond. |> Of course. The same is true of 128-bit ('quad') binary arithmetic, too. I |> rather assume most binary FP processing will migrate to that size, too, just |> as it migrated from single to double when the latter became widely |> available. Well, Kahan and others disagree, on very solid grounds. It may happen, but not in the foreseeable future. |> We are somewhat agreed on that :-). However, one can detect possible |> rounding even at the smaller sizes (with the effective loss of a digit of |> precision) by checking the MSD (which is conveniently in the top byte of the |> encoding). If it is still zero after a multiplication, for example, there |> was no rounding (except possibly for subnormal results, but when doing |> fixed-point arithmetic one is unliklely to be anywhere near the extremes of |> exponent range). If programming in assembler, yes, you can. You can ALMOST do that when using a high-level language as a pseudo-assembler, but I know of nobody skilled enough to achieve it for most important languages. It can be done for Java, for example, but not Fortran or the C-derived languages. Regards, Nick Maclaren.
