FIR Bandpass filtering (C code)
Started by Robert Krten ●March 31, 2007
rbj@ycrdi.com writes:
> [...] > FWIW, all this could just be crap.
I've often wondered if the problem isn't the algorithms being applied to the stock market but the sample rate. If you've got some wire feed coming in, it's going to limit your "sample rate," and whatever that is, it might not be enough. I wonder what the highest frequency of stock market data would be. Really. -- % Randy Yates % "And all that I can do %% Fuquay-Varina, NC % is say I'm sorry, %%% 919-577-9882 % that's the way it goes..." %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:
> rbj@ycrdi.com writes: >> [...] >> FWIW, all this could just be crap. > > I've often wondered if the problem isn't the algorithms > being applied to the stock market but the sample rate. If > you've got some wire feed coming in, it's going to limit > your "sample rate," and whatever that is, it might not > be enough. > > I wonder what the highest frequency of stock market data > would be. Really.
There are some pretty large day-to-day variations. When dealing with daily samples, any period shorter than two days will alias. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
Jerry Avins <jya@ieee.org> writes:
> Randy Yates wrote: >> rbj@ycrdi.com writes: >>> [...] >>> FWIW, all this could just be crap. >> I've often wondered if the problem isn't the algorithms >> being applied to the stock market but the sample rate. If you've got >> some wire feed coming in, it's going to limit >> your "sample rate," and whatever that is, it might not >> be enough. I wonder what the highest frequency of stock market data >> would be. Really. > > There are some pretty large day-to-day variations. When dealing with > daily samples, any period shorter than two days will alias.
Jerry, I was thinking of sample periods more on the order of milliseconds or even microseconds. I don't know why you're talking about days. -- % Randy Yates % "Maybe one day I'll feel her cold embrace, %% Fuquay-Varina, NC % and kiss her interface, %%% 919-577-9882 % til then, I'll leave her alone." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
