I'm developing on DSK with C6713. A want send data by EDMA at 100MHz to McBSP0. I configured EDMA and McBSP by DSP/BIOS Configurator. But, there is a problem. When I set Element length XWDLEN to 16-bits, everithing is OK, but, when I set Element length to 8-bits, output data are inconsistent. Example, when I sending 0xAA (10101010) at loop... 16-bits - OK - 101010101010101010101010101010101010101010101010101... 8-bits - ?? - 10101010????????10101010????????10101010????????101... ??? - it's something as hi impedance. Where is mistake? Is it possible sending 100MHz data with CPU at 200MHz? Thank for reply. -- MiLo
Problem with McBSP XWDLEN
Started by ●April 2, 2007
Reply by ●April 2, 20072007-04-02
Miloslav H�la wrote:> I'm developing on DSK with C6713. A want send data by EDMA at 100MHz > to McBSP0. I configured EDMA and McBSP by DSP/BIOS Configurator. > > But, there is a problem. When I set Element length XWDLEN to 16-bits, > everithing is OK, but, when I set Element length to 8-bits, output data > are inconsistent. > > Example, when I sending 0xAA (10101010) at loop... > > 16-bits - OK - 101010101010101010101010101010101010101010101010101... > 8-bits - ?? - 10101010????????10101010????????10101010????????101... > > ??? - it's something as hi impedance. > > Where is mistake? Is it possible sending 100MHz data with CPU at 200MHz? > > Thank for reply. > > -- MiLoLook at the data sheet. It says the maximum speed is CPU/2 or 75 MHz, whichever is smaller.
