why floating point need to be avoided in Real Time Systems ?
Started by shakes_ck ●April 3, 2007
Hi,
I read in some Design guidelines that floating point should be avoided in
Real Time systems. Why is it ?
Then how to maintain the required precision in that case ?
Regards,
shakes_ck
_____________________________________
Do you know a company who employs DSP engineers?
Is it already listed at http://dsprelated.com/employers.php ?
shakes_ck wrote:
> Hi, > I read in some Design guidelines that floating point should be avoided in > Real Time systems. Why is it ? > Then how to maintain the required precision in that case ? > > Regards, > shakes_ck > > _____________________________________ > Do you know a company who employs DSP engineers? > Is it already listed at http://dsprelated.com/employers.php ?
Whether to use fixed point code or floating point code depends on the particular application and what computations you're doing. Applications that do not have huge dynamic range can be implemented more efficiently and even more precisely using fixed point math. Other applications may require very large dynamic range making them better suited to floating point code. I think the more appropriate statement would be not to write floating point code to run on a fixed point processor. In that particular case it will be implemented through function calls rather than native floating point instructions causing a HUGE performance hit and making it harder to meet real-time deadlines. Brad
Probably just a guideline aimed particularly at PC users. The main issue is that on some floating point processors, certain ranges of values (particularly the "denormals") cause the computation time to increase dramatically, compared to the time for normalized numbers. Unfortunately, some of the things that people like to do in DSP or control systems involve recurrances that lead almost inevitably to sequences of denormalised numbers when the input goes to zero for periods of time. These sequences can be inconvenient and/or expensive to avoid, in general, and require at least some additional care. Most modern PCs, though, and almost all floating point DSP chips do not have this problem, because their floating point units can (or always do) flush values to zero instead of denormalised, and so can guarantee that the computation time will remain constant irrespective of the input values. This is the important condition that you need to be able to do real-time work.
If you avoid floating point, then you need to use a fixed point arithmetic model with sufficient precision for your task. Most DSP processors provide this, and it is readily possible to arrange the same on regular PC processors, too, but hardly necessary since those tend to have better support for floating point... Cheers, -- Andrew
Never mind. This is the old superstition which has to do with the performance penalty and some other problems associated with the use of the floating point on the ancient CPUs. Basically, the author of the guideline is trying to say that he is a cool guy because he can code the computations with the integers.
Floating point is not about the precision. It is about the range of representation. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote in news:PAsQh.5320
$Kd3.2328@newssvr27.news.prodigy.net:
> > Never mind. This is the old superstition which has to do with the > performance penalty and some other problems associated with the use of > the floating point on the ancient CPUs.
... and many current-day microcontrollers. -- Scott Reverse name to reply
Scott Seidman wrote:
>>Never mind. This is the old superstition which has to do with the >>performance penalty and some other problems associated with the use of >>the floating point on the ancient CPUs. > > ... and many current-day microcontrollers. >
A low end microcontroller of today is equivalent to a desktop PC of 15 years ago. In the majority of cases, there is no need to be a miser. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Hello,
In DSP applications, are there recoommended/ standard floating point to
fixed point conversion methods?
APS
Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote in news:E6tQh.5329
$Kd3.2007@newssvr27.news.prodigy.net:
> > > Scott Seidman wrote: > >>>Never mind. This is the old superstition which has to do with the >>>performance penalty and some other problems associated with the use of >>>the floating point on the ancient CPUs. >> >> ... and many current-day microcontrollers. >> > > A low end microcontroller of today is equivalent to a desktop PC of 15 > years ago. In the majority of cases, there is no need to be a miser. > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.com >
There are many fine MCU's that don't have floating point processors. The AVR Atmel and the PIC 18F spring immediately to mind, and flops take much more time than intops. Many DSP's do support floats, but that is a fairly beefy upgrade in terms of cost and development time. I'd think it would take less time to learn integer math than a new environment, as well. -- Scott Reverse name to reply
>>A low end microcontroller of today is equivalent to a desktop PC of 15 >>years ago. In the majority of cases, there is no need to be a miser. >> > There are many fine MCU's that don't have floating point processors. The > AVR Atmel and the PIC 18F spring immediately to mind, and flops take much > more time than intops.
I am very familiar with this stuff. Yes, for the AVRs and PICs the floating point is somewhat 20 times slower then the 16 bit integer. However it appears not to be a problem for many practical cases. What does matter is that the use of the floats requires a micro with 8k ROM at the least. This implies a MCU of $2 class, whereas the int arithmetics for the same functionality can probably be squeezed into the $1 class.
> Many DSP's do support floats, but that is a fairly > beefy upgrade in terms of cost and development time.
Actually, the use of floats greatly simplifies the development of the software. The DSPs with the hardware floating point are power hungry, and not designed to work as the standalone. I'd think it would
> take less time to learn integer math than a new environment, as well. >
I disagree. Optimizing the integer calculations, looking for overflows and bit losses is a tedious piece of work. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
There is nothing generically bad about floating point for real time work. However, many processors slow down horribly for very small numbers which will not normalise. The Pentium processors are very bad for this. People use fudges in their code to try to stop numbers denormalising, but it can still happen. This means the runtime of the code is rather unpredictable. It may run real time for 99.999% of the time, and then hiccup badly on a few small numbers.
Integers will generally give greater precision for the same word length. I think you are confusing precision with dynamic range. Steve
