Hi Folks, If you want to extract the frequency from a complex signal that contains a single, time-varying frequency component, then the straightforward method would be to determine the phase of the input signal and then run that phase into a differentiator. I'm thinking of a full-blown FIR differentiator with, say, 32 or more taps. The problem is, the phase has those bothersome discontinuities around +/- pi. You could unwrap it, but in fixed-point, you can only unwrap so far (think of what a single high-frequency sinusoid would result in phase-wise) before wrapping around the two's complement number. So, how to do? How do you get a phase input that's unwrapped for each M-1 previous samples into the FIR differentiator? This seems like a simple and common problem, but I'm coming up with zero. Maybe it's an off-night for me. -- % Randy Yates % "Bird, on the wing, %% Fuquay-Varina, NC % goes floating by %%% 919-577-9882 % but there's a teardrop in his eye..." %%%% <yates@ieee.org> % 'One Summer Dream', *Face The Music*, ELO http://home.earthlink.net/~yatescr
A Stupid FM Demod Question?
Started by ●April 3, 2007
Reply by ●April 3, 20072007-04-03
Randy Yates wrote:> Hi Folks, > > If you want to extract the frequency from a complex signal that > contains a single, time-varying frequency component, then the > straightforward method would be to determine the phase of the > input signal and then run that phase into a differentiator. I'm > thinking of a full-blown FIR differentiator with, say, 32 or > more taps. > > The problem is, the phase has those bothersome discontinuities > around +/- pi. You could unwrap it, but in fixed-point, you > can only unwrap so far (think of what a single high-frequency > sinusoid would result in phase-wise) before wrapping around > the two's complement number. > > So, how to do? How do you get a phase input that's unwrapped > for each M-1 previous samples into the FIR differentiator? > > This seems like a simple and common problem, but I'm coming > up with zero. Maybe it's an off-night for me.Randy, If you calculate the change in phase at each sample interval, then you don't need the differentiator. You already have frequency. I don't think the discontinuities will then be a problem. Provided the modulator produces phase changes of less than pi in any sample interval then there should be no ambiguity problem in determining the phase change. Regards, John
John Monro <johnmonro@optusnet.com.au> writes:> Randy Yates wrote: >> Hi Folks, >> If you want to extract the frequency from a complex signal that >> contains a single, time-varying frequency component, then the >> straightforward method would be to determine the phase of the >> input signal and then run that phase into a differentiator. I'm >> thinking of a full-blown FIR differentiator with, say, 32 or >> more taps. >> The problem is, the phase has those bothersome discontinuities >> around +/- pi. You could unwrap it, but in fixed-point, you >> can only unwrap so far (think of what a single high-frequency >> sinusoid would result in phase-wise) before wrapping around >> the two's complement number. >> So, how to do? How do you get a phase input that's unwrapped >> for each M-1 previous samples into the FIR differentiator? >> This seems like a simple and common problem, but I'm coming >> up with zero. Maybe it's an off-night for me. > > Randy, > > If you calculate the change in phase at each sample interval, then you > don't need the differentiator. You already have frequency. > > I don't think the discontinuities will then be a problem. Provided the > modulator produces phase changes of less than pi in any sample > interval then there should be no ambiguity problem in determining the > phase change.Hi John, Well that's what I *was* doing, but I started questioning the accuracy of the "two-sample differentiator." How do you know if the "two-sample differentiator" is good enough? What kind of distortion am I introducing when I use that as opposed to a more accurate multi-tap differentiator? -- % Randy Yates % "Midnight, on the water... %% Fuquay-Varina, NC % I saw... the ocean's daughter." %%% 919-577-9882 % 'Can't Get It Out Of My Head' %%%% <yates@ieee.org> % *El Dorado*, Electric Light Orchestra http://home.earthlink.net/~yatescr
Randy Yates <yates@ieee.org> writes:> John Monro <johnmonro@optusnet.com.au> writes: > >> Randy Yates wrote: >>> Hi Folks, >>> If you want to extract the frequency from a complex signal that >>> contains a single, time-varying frequency component, then the >>> straightforward method would be to determine the phase of the >>> input signal and then run that phase into a differentiator. I'm >>> thinking of a full-blown FIR differentiator with, say, 32 or >>> more taps. >>> The problem is, the phase has those bothersome discontinuities >>> around +/- pi. You could unwrap it, but in fixed-point, you >>> can only unwrap so far (think of what a single high-frequency >>> sinusoid would result in phase-wise) before wrapping around >>> the two's complement number. >>> So, how to do? How do you get a phase input that's unwrapped >>> for each M-1 previous samples into the FIR differentiator? >>> This seems like a simple and common problem, but I'm coming >>> up with zero. Maybe it's an off-night for me. >> >> Randy, >> >> If you calculate the change in phase at each sample interval, then you >> don't need the differentiator. You already have frequency. >> >> I don't think the discontinuities will then be a problem. Provided the >> modulator produces phase changes of less than pi in any sample >> interval then there should be no ambiguity problem in determining the >> phase change. > > Hi John, > > Well that's what I *was* doing, but I started questioning the accuracy > of the "two-sample differentiator." How do you know if the "two-sample > differentiator" is good enough? What kind of distortion am I introducing > when I use that as opposed to a more accurate multi-tap differentiator?Another questtion: Suppose we DO need to use a multitap filter for good accuracy. If we are using say 16-bit fixed-point two's complement arithmetic, and we scale the arctan output so that -pi corresponds precisely to -32768 and +pi to +32768, then would the differentiator MAC (assume we're using a 32-bit accumulator for the products) always wrap back to the proper interval? Kinda' like the fixed-point integrators do on a CIC? Would this happen? How to show? -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:> Hi Folks, > > If you want to extract the frequency from a complex signal that > contains a single, time-varying frequency component, then the > straightforward method would be to determine the phase of the > input signal and then run that phase into a differentiator.The straightforward way would be not to use the phase representation. Work with the complex derivatives directly: IdQ/dt - QdI/dt --------------- I^2 + Q^2 I'm> thinking of a full-blown FIR differentiator with, say, 32 or > more taps. > > The problem is, the phase has those bothersome discontinuities > around +/- pi.Yes, the phase has to be unwrapped, unless the differentiator is trivial twos complement [1 -1] or like. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Randy Yates wrote:> John Monro <johnmonro@optusnet.com.au> writes: > >> Randy Yates wrote: >>> Hi Folks, >>> If you want to extract the frequency from a complex signal that >>> contains a single, time-varying frequency component, then the >>> straightforward method would be to determine the phase of the >>> input signal and then run that phase into a differentiator. I'm >>> thinking of a full-blown FIR differentiator with, say, 32 or >>> more taps. >>> The problem is, the phase has those bothersome discontinuities >>> around +/- pi. You could unwrap it, but in fixed-point, you >>> can only unwrap so far (think of what a single high-frequency >>> sinusoid would result in phase-wise) before wrapping around >>> the two's complement number. >>> So, how to do? How do you get a phase input that's unwrapped >>> for each M-1 previous samples into the FIR differentiator? >>> This seems like a simple and common problem, but I'm coming >>> up with zero. Maybe it's an off-night for me. >> Randy, >> >> If you calculate the change in phase at each sample interval, then you >> don't need the differentiator. You already have frequency. >> >> I don't think the discontinuities will then be a problem. Provided the >> modulator produces phase changes of less than pi in any sample >> interval then there should be no ambiguity problem in determining the >> phase change. > > Hi John, > > Well that's what I *was* doing, but I started questioning the accuracy > of the "two-sample differentiator." How do you know if the "two-sample > differentiator" is good enough? What kind of distortion am I introducing > when I use that as opposed to a more accurate multi-tap differentiator?Hi Randy, I think using your original method, all you are introducing is errors in the frequency domain samples due to the amplitude-quantisation and the timing-jitter that is inherent in the original time-domain sampling process. Depending on the final baseband bandwidth you need, you may be able to clean up the frequency-domain signal using a LP filter, in effect averaging the frequency-domain samples you have generated. It seems to me that the signal will then have will be the best possible signal that can be extracted given the characteristics of the time-domain samples. Regards, John
Reply by ●April 4, 20072007-04-04
Vladimir Vassilevsky <antispam_bogus@hotmail.com> writes:> Randy Yates wrote: > >> Hi Folks, >> If you want to extract the frequency from a complex signal that >> contains a single, time-varying frequency component, then the >> straightforward method would be to determine the phase of the >> input signal and then run that phase into a differentiator. > > The straightforward way would be not to use the phase > representation. Work with the complex derivatives directly: > > IdQ/dt - QdI/dt > --------------- > I^2 + Q^2I guess the key advantage is that you don't have to implement an arctan function? Would you use an FIR differentiator to get Q' and I', making sure they're properly time-aligned with the I and Q values? -- % Randy Yates % "She has an IQ of 1001, she has a jumpsuit %% Fuquay-Varina, NC % on, and she's also a telephone." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:> Vladimir Vassilevsky <antispam_bogus@hotmail.com> writes: > > Randy Yates wrote: > > > >> If you want to extract the frequency from a complex signal that > >> contains a single, time-varying frequency component, then the > >> straightforward method would be to determine the phase of the > >> input signal and then run that phase into a differentiator. > > > > The straightforward way would be not to use the phase > > representation. Work with the complex derivatives directly: > > > > IdQ/dt - QdI/dt > > --------------- > > I^2 + Q^2 > > I guess the key advantage is that you don't have to implement an > arctan function? > > Would you use an FIR differentiator to get Q' and I', making sure > they're properly time-aligned with the I and Q values?actually Randy, you *do* have to implement an arctan() function for small angles, but you *don't* have to compute a derivative explicitly from these discrete samples (using some big FIR). omega[n] = arg{ I[n] + j*Q[n] } - arg{ I[n-1] + j*Q[n-1] } = arctan( Q[n]/I[n] ) - arctan( Q[n-1]/I[n-1] ) = arctan( (Q[n]*I[n-1] - I[n]*Q[n-1]) / (I[n]*I[n-1] +Q[n]*Q[n-1]) ) the measure omega[n] is simple that of how much the phase of I + j*Q has advanced from the phase of the previous sample. isn't that what frequency is? how much (in a given period of time) the phase angle advances? r b-j
"robert bristow-johnson" <rbj@audioimagination.com> writes:> Randy Yates wrote: >> Vladimir Vassilevsky <antispam_bogus@hotmail.com> writes: >> > Randy Yates wrote: >> > >> >> If you want to extract the frequency from a complex signal that >> >> contains a single, time-varying frequency component, then the >> >> straightforward method would be to determine the phase of the >> >> input signal and then run that phase into a differentiator. >> > >> > The straightforward way would be not to use the phase >> > representation. Work with the complex derivatives directly: >> > >> > IdQ/dt - QdI/dt >> > --------------- >> > I^2 + Q^2 >> >> I guess the key advantage is that you don't have to implement an >> arctan function? >> >> Would you use an FIR differentiator to get Q' and I', making sure >> they're properly time-aligned with the I and Q values? > > actually Randy, you *do* have to implement an arctan() function for > small angles, but you *don't* have to compute a derivative explicitly > from these discrete samples (using some big FIR). > > omega[n] = arg{ I[n] + j*Q[n] } - arg{ I[n-1] + j*Q[n-1] } > > = arctan( Q[n]/I[n] ) - arctan( Q[n-1]/I[n-1] ) > > = arctan( (Q[n]*I[n-1] - I[n]*Q[n-1]) / (I[n]*I[n-1] > +Q[n]*Q[n-1]) )How did you get from the second line to the third?> the measure omega[n] is simple that of how much the phase of I + j*Q > has advanced from the phase of the previous sample. isn't that what > frequency is? how much (in a given period of time) the phase angle > advances?I always thought that frequency is the derivative of phase, f = dtheta/dt. That's the gist of my question. Do I need to perform a full derivative or is theta2 - theta1 perfect or good enough? Seems like, going back to first semester calculus, theta2-theta1 is the average slope in the period t1 to t2, and that the true instantaneous slope would be dtheta/dt. -- % Randy Yates % "Remember the good old 1980's, when %% Fuquay-Varina, NC % things were so uncomplicated?" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
