Hi,all I would like to find the expected value of my OFDM transmitted signal. As Y= H*X + N Y= Received Signal , H = Channel , X= transmitted signal ,N=noise Since i need to generate a MMSE equalizer, i need to find the Expected value of X , in order to do the simulation. The algorithm of MMSE equalizer is Gmmse= Ru * Transpose(H) * inv(Rn+ H * Ru * Transpose(H)) Where Ru = E[ x(i) * transpose(x(i)] and Rn=E [ n(i) * transpose(n(i))] Actually, I have try to use the exact transmitted signal to generate the mmse equalizer and the simulation, but i have noticed that the Error of my signal is unacceptable large. Even a ZF equalizer also has a better performance than it... Therefore i think the problem might really come from the expected value Ru and Rn. i really hope some one can help me...i am really frustrated on it. Thank you. _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
How to get the expected value of the transmitted signal?
Started by ●April 6, 2007
Reply by ●April 6, 20072007-04-06
On Apr 6, 9:41 am, "ericknightX" <wil...@gmail.com> wrote:> Hi,all > > I would like to find the expected value of my OFDM transmitted signal. > > As > > Y= H*X + N > > Y= Received Signal , H = Channel , X= transmitted signal ,N=noise > > Since i need to generate a MMSE equalizer, i need to find the Expected > value of X , in order to do the simulation. > > The algorithm of MMSE equalizer is > > Gmmse= Ru * Transpose(H) * inv(Rn+ H * Ru * Transpose(H)) > > Where Ru = E[ x(i) * transpose(x(i)] and Rn=E [ n(i) * transpose(n(i))] > > Actually, I have try to use the exact transmitted signal to generate the > mmse equalizer and the simulation, but i have noticed that the Error of my > signal is unacceptable large. Even a ZF equalizer also has a better > performance than it... > > Therefore i think the problem might really come from the expected value Ru > and Rn. > i really hope some one can help me...i am really frustrated on it.Ru and Rn are not the expected values of X and N, they are the covariance matrices. In fact, the MMSE equation you have above presupposes that E(X) and E(N) are both zero. In an OFDM scenario, it is quite likely that Ru and Rn are both diagonal matrices (and possibly with all diagonal entries the same). -- Oli
