when trying to determine the correlation between a waveform contained in two asynchronously sampled series, either through cross correlation or other techniques, is it common to perform some type of signal reconstruction beforehand? It would seem if I am sampling at 4x the max bandwidth, the max possible phase difference would yield huge errors if I just compared sample to sample (take two 50Hz sine waves randomly sampled at 200Hz for instance). Now if I reconstructed the intermediate points with a sinc function, obviously, I could obtain much better results, or alternatively oversample by 10 or 20x. steve
Digital Waveform comparision question
Started by ●April 7, 2007
Reply by ●April 7, 20072007-04-07
On 8 Apr, 00:39, "steve" <bungalow_st...@yahoo.com> wrote:> when trying to determine the correlation between a waveform contained > in two asynchronously sampled series, either through cross > correlation or other techniques, is it common to perform some type of > signal reconstruction beforehand?It depends on what you mean by "asynchronous sampling." I would expect that two time series which are sampled with the same samling rate ought to be comparable. If there two sampling rates in the two systems are off by a "significant" amount, things might become worse.> It would seem if I am sampling at 4x the max bandwidth, the max > possible phase difference would yield huge errors if I just compared > sample to sample (take two 50Hz sine waves randomly sampled at 200Hz > for instance)."Randomly sampled" is an ambiguous term. Do you mean that the dat are sampled at random points, or at a fixed samling rate but with random phase?> Now if I reconstructed the intermediate points with a sinc function, > obviously, I could obtain much better results, or alternatively > oversample by 10 or 20x.Assuming you want to measure relative time delays, you could consider analyzing the phase of the cross spectrum. Rune
On Apr 7, 4:08 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote:> On 8 Apr, 00:39, "steve" <bungalow_st...@yahoo.com> wrote: > > > when trying to determine the correlation between a waveform contained > > in two asynchronously sampled series, either through cross > > correlation or other techniques, is it common to perform some type of > > signal reconstruction beforehand? > > It depends on what you mean by "asynchronous sampling." > I would expect that two time series which are sampled > with the same samling rate ought to be comparable. > If there two sampling rates in the two systems are off > by a "significant" amount, things might become worse. > > > It would seem if I am sampling at 4x the max bandwidth, the max > > possible phase difference would yield huge errors if I just compared > > sample to sample (take two 50Hz sine waves randomly sampled at 200Hz > > for instance). > > "Randomly sampled" is an ambiguous term. Do you mean that > the dat are sampled at random points, or at a fixed samling > rate but with random phase? > > > Now if I reconstructed the intermediate points with a sinc function, > > obviously, I could obtain much better results, or alternatively > > oversample by 10 or 20x. > > Assuming you want to measure relative time delays, you > could consider analyzing the phase of the cross spectrum. > > RuneI meant fixed sampling. I'm not interesed in relative delay, but a measure of similarity of the two waveforms (as a simple example say a pure sine wave as a template compared to an incoming distorted sine wave)
Reply by ●April 8, 20072007-04-08
On 8 Apr, 02:50, "steve" <bungalow_st...@yahoo.com> wrote:> On Apr 7, 4:08 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote: > > > > > > > On 8 Apr, 00:39, "steve" <bungalow_st...@yahoo.com> wrote: > > > > when trying to determine the correlation between a waveform contained > > > in two asynchronously sampled series, either through cross > > > correlation or other techniques, is it common to perform some type of > > > signal reconstruction beforehand? > > > It depends on what you mean by "asynchronous sampling." > > I would expect that two time series which are sampled > > with the same samling rate ought to be comparable. > > If there two sampling rates in the two systems are off > > by a "significant" amount, things might become worse. > > > > It would seem if I am sampling at 4x the max bandwidth, the max > > > possible phase difference would yield huge errors if I just compared > > > sample to sample (take two 50Hz sine waves randomly sampled at 200Hz > > > for instance). > > > "Randomly sampled" is an ambiguous term. Do you mean that > > the dat are sampled at random points, or at a fixed samling > > rate but with random phase? > > > > Now if I reconstructed the intermediate points with a sinc function, > > > obviously, I could obtain much better results, or alternatively > > > oversample by 10 or 20x. > > > Assuming you want to measure relative time delays, you > > could consider analyzing the phase of the cross spectrum. > > > Rune > > I meant fixed sampling. I'm not interesed in relative delay, but a > measure of similarity of the two waveforms (as a simple example say a > pure sine wave as a template compared to an incoming distorted sine > waveThere is a standard text which deals with such questions: Bendat & Piersol "Random Data" (Wiley 2000) The key word to look for is "coherence". Rune
On Apr 8, 6:15 am, "Rune Allnor" <all...@tele.ntnu.no> wrote:> On 8 Apr, 02:50, "steve" <bungalow_st...@yahoo.com> wrote: > > > > > > > On Apr 7, 4:08 pm, "Rune Allnor" <all...@tele.ntnu.no> wrote: > > > > On 8 Apr, 00:39, "steve" <bungalow_st...@yahoo.com> wrote: > > > > > when trying to determine the correlation between a waveform contained > > > > in two asynchronously sampled series, either through cross > > > > correlation or other techniques, is it common to perform some type of > > > > signal reconstruction beforehand? > > > > It depends on what you mean by "asynchronous sampling." > > > I would expect that two time series which are sampled > > > with the same samling rate ought to be comparable. > > > If there two sampling rates in the two systems are off > > > by a "significant" amount, things might become worse. > > > > > It would seem if I am sampling at 4x the max bandwidth, the max > > > > possible phase difference would yield huge errors if I just compared > > > > sample to sample (take two 50Hz sine waves randomly sampled at 200Hz > > > > for instance). > > > > "Randomly sampled" is an ambiguous term. Do you mean that > > > the dat are sampled at random points, or at a fixed samling > > > rate but with random phase? > > > > > Now if I reconstructed the intermediate points with a sinc function, > > > > obviously, I could obtain much better results, or alternatively > > > > oversample by 10 or 20x. > > > > Assuming you want to measure relative time delays, you > > > could consider analyzing the phase of the cross spectrum. > > > > Rune > > > I meant fixed sampling. I'm not interesed in relative delay, but a > > measure of similarity of the two waveforms (as a simple example say a > > pure sine wave as a template compared to an incoming distorted sine > > wave > > There is a standard text which deals with such questions: > > Bendat & Piersol "Random Data" (Wiley 2000) > > The key word to look for is "coherence". > > Rune- Hide quoted text - > > - Show quoted text -ok, I will check it out, thanks
