please help me it remains me just one month for present my final project !!!!! and i didn't find yet a solution to my problem!!! my subject is an implementation of optimal filter on DSP (image filter) and my problem is that when i introduce the input file (of my image) my output file is always empty (zero).....i think that my problem is what write in ADDRESS field of "probe point" or "load and save" address, and what choose: data or program or I/O ? please if anybody can help me urgently .....i repeat that i do just a simulation....not an emulation. thanks for all
HELP URGENTLY for using DSP (TMS320C5000) simulator
Started by ●May 24, 2004
Reply by ●May 25, 20042004-05-25
Any reason for using probe points instead of normal file read/write (stdio). That should be easier to use and apparently more suitable for your context. Regards Piyush yasmine_boulfani@yahoo.fr (B.yasmine) wrote in message news:<71db2c9f.0405240124.1da6053@posting.google.com>...> please help me it remains me just one month for present my final > project !!!!! and i didn't find yet a solution to my problem!!! > my subject is an implementation of optimal filter on DSP (image > filter) > and my problem is that when i introduce the input file (of my image) > my output file is always empty (zero).....i think that my problem is > what write in ADDRESS field of "probe point" or "load and save" > address, and what choose: data or program or I/O ? > please if anybody can help me urgently .....i repeat that i do just a > simulation....not an emulation. > thanks for all
Hi, you all right in understanding: must set the second probe point, it connect with output file(i.e. save) & data region(address from map-file, to check use 'View-Memory'). Cheers
>>>>> "Piyush" == Piyush Kaul <piyushkaul@yahoo.com> writes:Piyush> Any reason for using probe points instead of normal file read/write Piyush> (stdio). That should be easier to use and apparently more suitable for Piyush> your context. In my experience, probe points work a whole lot better and more reliably than fread/fwrite, and are way faster than printf/scanf. Ray
