Hi there, Is this true, that's impossible to create properly working FIR using VisualDSP 3.0 for 21061 EZ-Kit ? I tried to run simple FIR (using different codes, samplerates and coefficients), and only what I got is noise :( Is there anybody, who have a working FIR filter project written in C for 21061 EZ-Lite ? Thanks, Jarek
Looking for FIR in C for 21061 EZ-Kit
Started by ●April 12, 2007
Reply by ●April 13, 20072007-04-13
On 12 Apr., 22:13, Jarek <a...@me.4> wrote:> Hi there, > > Is this true, that's impossible to create properly working FIR using > VisualDSP 3.0 for 21061 EZ-Kit ? > > I tried to run simple FIR (using different codes, samplerates and > coefficients), and only what I got is noise :( > > Is there anybody, who have a working FIR filter project written in C for > 21061 EZ-Lite ?There is example C code for an FIR in this sub-directory: ...\21k\Examples\C_Examples\C-FIR "..." is the installation directory of VisualDSP. This example uses fixed-point processing. Be careful with the format of the input to the FIR routine, it must also be fixed-point (Q32). However, you cannot use the hardware circular buffers in C, and the example code actually goes and manually shifts each delay, which is hopelessly inefficient. If you insist on using C (in assembler, the whole exercise can be implemented in 4 instructions), you should consider one of the tricks mentioned under "Part 4: FIR Implementation" in the DspGuru FIR faq: http://www.dspguru.com/info/faqs/firfaq.htm Regards, Andor
