Scott Dorsey wrote...>> I need to do fourier analysis on speech files. > > That's good. > >> is it possible to do it right from MP3 files? > > No, but it's fascinating to watch the spectra of MP3 files, because you > see these huge blocks of missing data. The perceptual encoding system > totally screws with the spectrum. > >> if not, is it possible to do convert MP3 files to WAV ones? > > Sure, but the data is already long gone before then. The MP3 encoding > system removes data, and once data is lost, you cannot ever get it back.If you would you be happy using minidisk recordings then MP3 recorded with a decent encoder at 44.1kHz/160kbps per channel will also be perfectly acceptable, since it actually does less damage than ATRAC 4.5. See www.avisoft.com/compression.htm for a comparison and discussion on Lossy Audio Data Compression Effects. The point is that the higher the bit rate the less lossy compression needs to be applied by the MP3 encoder. The real horror stories that I have seen described have used MP3 bit rates as low as 8 or 16 kbps and indeed do show significant loss of harmonic content due to psychoacoustic masking compression. However the effects are very much less when using a bit rate ten or twenty times greater. Obviously you must make comparisons between MP3 and uncompressed formats to confirm that the difference between the two is not significant to the level of your analysis - but you shouldn't dismiss the MP3 format out of hand. David
fourier analysis/MP3 to WAV format conversion
Started by ●April 14, 2007
Reply by ●April 14, 20072007-04-14
Reply by ●April 15, 20072007-04-15
> See www.avisoft.com/compression.htm for a comparison and discussion on Lossy Audio Data Compression Effects~ David your link was excellent at illustrating the point you made but it was "visual" ;-) ~ Are there Mathematical studies going in depth into the WAV/lossless vs MP3/lossy compression? ~ I am asking here because you have a good grounding on these issues "googling" may make you wasted your little time ~ Thank you lbrtchx
Reply by ●April 16, 20072007-04-16
hi, you may convert mp3 files back into wav files using freeware cross-platform LAME converter: http://www.free-codecs.com/download/Lame_Encoder.htm download, unpack it in any directory and run with --help or --longhelp good luck! -andrejs <lbrtchx@hotmail.com> wrote in message news:1176532085.531344.173200@b75g2000hsg.googlegroups.com...> if not, is it possible to do convert MP3 files to WAV ones? > ~
