"David Morgan (MAMS)" <findme@m-a-m-s.comC/Odm> wrote in message news:Q4fUh.3418$h8.2551@trnddc06...> > "Richard Crowley" <rcrowley@xp7rt.net> wrote in message news:1322seppkmblh0a@corp.supernews.com... > > "David Morgan (MAMS)" wrote... > > > "Richard Crowley" wrote ... > > >> "David Morgan (MAMS)" wrote ... > > >> > "Mark" wrote ... > > >> >> > > > >> >> > > It seems that the call is being dropped > > >> >> > > or moved forward during the outgoing prompt.> > >> >> If the call center equipment is interpretting the outgoing audio > > >> >> voice'prompt as a touch tone, then that is "talk off". Lowering > > >> >> the outgoing audio level a few dB can make a big difference. > > >> >> > > >> >> comp.dsp is a newsgroup like this one, nothing to sign up for, > > >> >> just > > >> >> post... > > >> >> > > >> >> Mark> > >> > Four days and not one single response on comp.dsp> > >> One equation, seventeen variables.> > > Uhh... care to elaborate, or am I missing the smiley-face?> > It seemed like you had a great many different parameters > > in the situation which made it a less likely candidate for a > > problem that could be solved at long distance here on a > > newsgroup.> The basic parameters were the gear and recorded distortion. > > I believe that I have solved the problem on the surface, at the > initial point of the recording of voice prompts.... but I'd like to > understand more about how the end user of this automated > response software implements it with the phone lines, in the > event there are more opportunities for such an anomaly to > creep in further down the path. > > DM
Re: VOIP, Call Center, and DTMF errors...
Started by ●April 14, 2007
