When one discretizes a transfer function, does one loose accuracy in the center frequency? If yes, how can one compensate so that accuracy is not lost? I have an analog transfer function. When ever I run the bilinear transform on it and plot the frequency response, the center frequency is shifted.
Accuracy when Setting Center Frequency
Started by ●April 15, 2007
Reply by ●April 15, 20072007-04-15
Chris Barrett wrote:> When one discretizes a transfer function, does one loose accuracy in the > center frequency?No.> If yes, how can one compensate so that accuracy is not lost?The answer was 'no', but you can compensate for the real problem.> I have an analog transfer function. When ever I run the > bilinear transform on it and plot the frequency response, the center > frequency is shifted.The bilinear transform warps critical frequencies. Low frequencies aren't much affected, but infinite frequency maps to Fs/2. A single important frequency can be "prewarped". If w is the frequency you want after z transforming, the w' to use before is (IIRC) 2*Fs*tan(w/2). You don't really want to prewarp the center frequency of a band-pass filter. Both band edges will come out wrong. It's OK to start a design that way and then vary center frequency and bandwidth iteratively to come out where you want. Modern filter programs make that easier than finding the solution to the non-linear equation. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
On 15 Apr, 20:05, Jerry Avins <j...@ieee.org> wrote:> You don't really want to prewarp the center frequency of a band-pass > filter. Both band edges will come out wrong. It's OK to start a design > that way and then vary center frequency and bandwidth iteratively to > come out where you want. Modern filter programs make that easier than > finding the solution to the non-linear equation.If this is a question of designing a discrete-time filter from a continuous-time prototype, you would want to be very careful about how to organize the flow of the job. How I would do this: - Specify Fs, corner frequencies and attenuations in pass band and stop and in discrete-time domain - Pre-warp this specification to continuous-time domain - Use the analog formulas to design a CT low-pass prototype - Use the BLT to transform the LP prototype from CT to DT domain, making very sure to keep track of corner frequencies - Apply an LP -> BP frequency transform in digital domain in order to produce a bandpass filter with the correct corner frequencies As you can see, the center frequency never enters the discussion and is not important. I have no idea whether the center frequency of the analog spec would map to the center frequency to the digital spec; I would be surprised if it can be shown that it always does. Rune
Rune Allnor wrote:> On 15 Apr, 20:05, Jerry Avins <j...@ieee.org> wrote: > >> You don't really want to prewarp the center frequency of a band-pass >> filter. Both band edges will come out wrong. It's OK to start a design >> that way and then vary center frequency and bandwidth iteratively to >> come out where you want. Modern filter programs make that easier than >> finding the solution to the non-linear equation. > > If this is a question of designing a discrete-time filter from > a continuous-time prototype, you would want to be very careful > about how to organize the flow of the job. > > How I would do this: > > - Specify Fs, corner frequencies and attenuations in pass band > and stop and in discrete-time domain > - Pre-warp this specification to continuous-time domain > - Use the analog formulas to design a CT low-pass prototype > - Use the BLT to transform the LP prototype from CT to DT domain, > making very sure to keep track of corner frequencies > - Apply an LP -> BP frequency transform in digital domain > in order to produce a bandpass filter with the correct > corner frequencies > > As you can see, the center frequency never enters the > discussion and is not important. > > I have no idea whether the center frequency of the analog > spec would map to the center frequency to the digital spec; > I would be surprised if it can be shown that it always does.It's easy to show that it never does, an excersize in arm waving left for the reader. The analog band-pass design procedures I know take as inputs center frequency and bandwidth. Can you tell me about any that explicitly use the band edges? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Reply by ●April 16, 20072007-04-16
On Apr 15, 5:24 pm, Jerry Avins <j...@ieee.org> wrote:> > The analog band-pass design procedures I know take as inputs center > frequency and bandwidth. Can you tell me about any that explicitly use > the band edges?it turns out that for every degree of freedom (or independent frequency parameter) you have for the analog filter, it's also a degree of freedom for the digital filter (at least with the BLT mapping) and you can compensate (pre-warp) for each independent frequency parameter, if that's what you want to do. i dunno if i want to get bogged down with this, but my recommendation is first design the analog filter completely in normalized "s", that is an analog filter where the most significant frequency (the one you really want to be spot on, even after transformation) at f0=1/(2*pi) or omega0 = 2*pi*f0 = 1 or when s = j. this is legitimate because there is no mathematical qualitative difference between 10 Hz, 100 Hz, or a zillion Hz. it all just a matter of choice of units and the accompanying conversion factors. in this case, a simple LPF will look like: H(s) = 1/(1 + s) or, for 2nd order H(s) = 1/(1 + s/Q + s^2) or for a 2nd order BPF H(s) = s/(1 + s/Q + s^2) whatever. what you DON'T see are transfer functions that have the significant frequency as a parameter like H(s) = (s/omega0) / (1 + (s/omega0)/Q + (s/omega0)^2) because we're deliberately choosing our units in continuous time so that to make that scaling factor go away. then to BLT that to the z-domain and fix that frequency warping problem (inherent to the BLT) automatically, one substitutes: s <- 1/tan(w0/2) * (1 - z^-1)/(1 + z^-1) where w0 is where your significant radian frequency is in normalized digital frequency (that is the scale where Nyquist = pi). that would mean that w0 = omega0/Fs = 2*pi*f0/Fs where Fs is the sampling frequency measured in the units as is f0 (not radian frequency). there are some nice trig identies for that tan(w0/2) that you can use. what about the bandedges? well, this depends on what it is you wanna do. it turns out that the BLT frequency warping will tend to push the bandedges closer to each other (in log frequency) as w0 increases. in some cases, it may be desirable to compensate for this "skrunching" of the bandwidth in a similar way that one compensates for frequency warping of the significant (center) frequency. take, for instance the above BPF. at the center frequency, the gain of this BPF is Q. this peak gain is different from a constant gain you can always toss in because as Q gets larger, the peak gain gets larger whereas the "skirts" of the frequency response do not change. if it were a constant gain factor increasing, all of the frequency response would increase by the same dB. so, suppose this gain at resonance (even for an LPF) is what is important to you. then do nothing about the bandedges, because of the mapping of the BLT, every bump and ripple in the analog filter shows up in the digital filter with the same gain, but at different (warped) frequencies. but if bandwidth is important, then you might want to "pre-warp" that specifaction to begin with. the 1st-order approximation for doing that in log frequency is: analog BW = w0/sin(w0) * (digital BW) this is assuming you still want the significant (center) frequency to be placed precisely where you want it. normally for a BPF, you have two degrees of freedom with the bandedges and significant frequency, not three. you can place the upper and lower bandedge precisely where you want them, but then you have to take what you get regarding the center frequency. or you can place the center frequency precisely where you want it and *one* bandedge at exact locations (providing neither go over Nyquist) and take what life dishes out regarding the other bandedge. or you can place the center frequency and the *difference* of the bandedges (whether in linear frequency or log frequency), what we normally think of the "bandwidth", but neither bandedge will come out to be exactly where they were for the analog prototype. i'll admit, i did a lot of thinking about this ca. 1993/94 and some since. r b-j
On 15 Apr, 23:24, Jerry Avins <j...@ieee.org> wrote:> The analog band-pass design procedures I know take as inputs center > frequency and bandwidth. Can you tell me about any that explicitly use > the band edges?None that I have found elsewhere or have found a published name for. I designed my pocedure from the point of view that the end product is a discrete-time domin filter which is to be implemented in double precision floating point arithmetics. This in contrast to somebody who have to implement an analog filter as an RLC cirquit with 20% tolerance on the components. Rune
robert bristow-johnson wrote: ...> what about the bandedges? well, this depends on what it is you wanna > do. it turns out that the BLT frequency warping will tend to push the > bandedges closer to each other (in log frequency) as w0 increases. in > some cases, it may be desirable to compensate for this "skrunching" of > the bandwidth in a similar way that one compensates for frequency > warping of the significant (center) frequency....> but if bandwidth is important, then you might want to "pre-warp" that > specifaction to begin with. the 1st-order approximation for doing > that in log frequency is: > > analog BW = w0/sin(w0) * (digital BW) > > this is assuming you still want the significant (center) frequency to > be placed precisely where you want it. normally for a BPF, you have > two degrees of freedom with the bandedges and significant frequency, > not three. you can place the upper and lower bandedge precisely where > you want them, but then you have to take what you get regarding the > center frequency. or you can place the center frequency precisely > where you want it and *one* bandedge at exact locations (providing > neither go over Nyquist) and take what life dishes out regarding the > other bandedge. or you can place the center frequency and the > *difference* of the bandedges (whether in linear frequency or log > frequency), what we normally think of the "bandwidth", but neither > bandedge will come out to be exactly where they were for the analog > prototype.For practical purposes, the center frequency of a flat topped bandpass filter is half way between the band edges. Operationally, that's the only special thing about it. So you put the upper and lower band edges where they're wanted, and the rest is a matter of technique. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Reply by ●April 17, 20072007-04-17
On Apr 16, 9:22 am, Jerry Avins <j...@ieee.org> wrote:> > For practical purposes, the center frequency of a flat topped bandpass > filter is half way between the band edges.in log frequency? (the answer is "yes" for when the center frequency is far below Nyquist, which it is for the analog prototype, having an "infinite" Fs, but in a digital filter, it so happens that when the center frequency is at Nyquist/2, then it's symmetrical in linear frequency.)> Operationally, that's the > only special thing about it. So you put the upper and lower band edges > where they're wanted, and the rest is a matter of technique.it's also a matter of what is desired in the end product. sometimes, the precise location of the resonant frequency is more important than the precise location of the bandedges. at least i can imagine so for some audio application. r b-j
