uneven quantization
Started by Unknown April 15, 2007
I would like to know how can I make an uneven quantization !!
I would like to get straight lines (approximation of the random
curve) !! It is some sort of quantization where I have also average
it !!
Can anybody help ?
Thanks
Ali
dragonboy.ali@gmail.com wrote:
> I would like to know how can I make an uneven quantization !! > > I would like to get straight lines (approximation of the random > curve) !! It is some sort of quantization where I have also average > it !!
> Can anybody help ?
Probably, if you explain in more detail what you want to do and how it is connected to quantization. What does " !!" imply? Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Jerry Avins wrote:
>> I would like to get straight lines (approximation of the random >> curve) !! It is some sort of quantization where I have also average >> it !! > > > What does " !!" imply?
Didn't you figure it out? The first exclamation mark implies "no clue", the second one means "right now", the third one is "for gratis", the forth is "homework", the fifth is "imbecile". If you can read between the lines, you can see the whole story behind those exclamation signs. VLV
On Apr 15, 5:29 pm, Jerry Avins <j...@ieee.org> wrote:
> dragonboy....@gmail.com wrote: > > I would like to know how can I make an uneven quantization !! > > > I would like to get straight lines (approximation of the random > > curve) !! It is some sort of quantization where I have also average > > it !! > > > Can anybody help ? > > Probably, if you explain in more detail what you want to do and how it > is connected to quantization. > > What does " !!" imply? > > Jerry > --
Hello Jerry, I can't speak for the OP, but in math terms !! means double factorial. For example n!! is the product of every other number up to and including n starting from either 1 or 2 depending on whether or not n is even or odd. I.e., 5!! means 1*3*5 and 10!! means 2*4*6*8*10 This shows up in some representations of Bessel function series among others. Clay
