Hi all, In the case I don't know the sampling frequency. Specifically, I only given a discrete function: f[n]= blah blah..... with length N. I use wavelet based compression method: Decompose the signal into N wavelet coefficients, quantize and then encode these coefficients with M bits for each coefficient. Now to report the algorithm, I need to submit it's RATE. In the case, what formula is for RATE calculation? I guess it will be Size of compressed data / size of original data I know the size of my compressed data: it is the number of bits * number of coefficients= M*N bits But what is the size of my original data :(f(n))?? Thanks
Formula to calculate the rate for a compression algorithm
Started by ●April 18, 2007
Reply by ●April 18, 20072007-04-18
On Apr 18, 11:23 am, "A.E lover" <aelove...@gmail.com> wrote:> Hi all, > > In the case I don't know the sampling frequency. Specifically, I only > given a discrete function: > > f[n]= blah blah..... with length N. > > I use wavelet based compression method: > > Decompose the signal into N wavelet coefficients, quantize and then > encode these coefficients with M bits for each coefficient. > > Now to report the algorithm, I need to submit it's RATE. In the case, > what formula is for RATE calculation? > > I guess it will be Size of compressed data / size of original data > > I know the size of my compressed data: it is the number of bits * > number of coefficients= M*N bits > > But what is the size of my original data :(f(n))?? > > ThanksAssuming all 'blah' have same number of bits, would that not be: (number of bits per 'blah')*N ? Dirk
