Error connecting to the target: Error 0x80002200/-291 Fatal Error during: OCS, Control, This error was generated by TI's USCIF driver. I m getting this error.... and our tclk frequency is 500kHz.... please reply to my problem .... regards, mahesh SC_ERR_TST_MEASURE <-291> The built-in scan-path length measurement has failed. This indicates that the JTAG controller cannot reliably communicate with the target DSP's and micro-controllers at that frequency. Try specifying the scan-path lengths in the board configuration file because the built-in scan-path reliability tests cannot be performed without knowledge of the scan-path length. Sequence ID: 0 Error Code: -291 Error Class: 0x80002200 Board Name: OMAP2430_BH560M Cpu Name: ICEPICK_B_0 Abort: Close Code Composer Studio. Retry: Try to connect to the target again. Cancel: Remain disconnected from the target Diagnostic: Run diagnostic utility. _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
JTAG error generated by TI's USCIF driver
Started by ●April 19, 2007
