I saw a previous thread about this problem but i have some further questions since i am experiencing some problem. I am using the ADSP-21369 and want to define a global variable in the external memory. I am using the Block Based Talkthrough program (C) provided with the VDSP++. i am doing this in tt.h to define two varialbes in the section seg_sdram section("seg_sdram") float tt; section("seg_sdram") float rr; in order for the compiler to acknowledge these sections i have added following lines to the LDF file (ADSP-21369.LDF) MEMORY { //external seg_sram { TYPE(DM RAM) START(0x00200000) END(0x0021FFFF) WIDTH(32)} seg_sdram { TYPE(DM RAM) START(0x08000000) END(0x083FFFFF) WIDTH(32)} this should define the memory adresses and then i define SECTIONS { //external seg_sram { INPUT_SECTIONS( $OBJECTS(seg_sram)) } > seg_sram seg_sdram { INPUT_SECTIONS( $OBJECTS(seg_sdram)) } > seg_sdram so the sections should be known but i still get an error [Warning li2060] The following input section(s) that contain program code and/or data have not been placed into the executable for processor 'p0' as there are no relevant commands specified in the LDF: my quesion is why isnt there any relavent commands specified when i have specified them? _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
VisualDSP++ ADSP-21369: Acessing External Memory
Started by ●April 24, 2007
